01-13-2017, 08:29 AM
Originally Posted by Vlad
I had the oversize washers then decided to remove them. They require even longer bolts.
I recommend going back to the washers. Even though they do require longer bolts, the load is spread much more evenly.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
01-13-2017, 08:37 AM
I will follow your recommendation Mel. Plus it's a good reason to fly to Canada. I know a place there with tons of free washers.
01-13-2017, 09:04 AM
Originally Posted by pastranafan5
What are your favorite products from this company and why? I'm going to buy some stuff and want to know what all I should get.
Nose Gear brace
Gust lock
Would love to install the Almost 14 in my 7A, little scared of screwing up something important in the structure, canopy fit (slider).
Superior people
Superior products
Peter
RV7A New Dec 2013 - 360, C/S, slider
RV6 - 1600 Hours ---- Sold
01-13-2017, 09:57 AM
Anti-Splat Aero - Excellent!
1. Nose job
2.Oil separator
3. Nose wheel bearing mod
4. Vertical stabilizer bracket
5. Almost-a- RV-14 mod (absolutely love my seating position now!)
6. Lip skid
7. Axle and nose fork nut wrench
8. Pulse oximeter (fun to play with)
As others have said, service from Anti-Splat is quick and friendly. They are always a pleasure to deal with.
Lars
Ottawa, Canada
RV-9A C-FSLE - First flight May 7, 2015
Skybolt C-GSLE - built, flown and sold
Donation sent to DR - 2016
01-15-2017, 04:17 PM
1. Nose gear brace
2. Nose wheel bearing mod
3. Skid plate
4. Gust lock
5. Almost a 14 seat mod
The seat mod really made the plane roomier. A friend of mine sat in my plane and ordered one for his 9A, although after installation he found he needed a little thicker seat cushion for landings.
Jeff Kintzle
RV-9A. N43KK
01-17-2017, 10:53 AM
Thanks guys. I ended up getting the nose job, nose wheel bearing mod, air oil separator, and vacuum kit.
01-17-2017, 02:20 PM
almost 14 for petersb
I think I did the first 14 seat mod to a tip up and I want to do another in either tip up or slider. After doing mine I think it would work well to put the brace in place before you remove the original seat back brace. This should eliminate any movement of parts that might result in any misalignment of the canopy.
I just picked up my latest antisplat order. Not only did I get it in three days but for some reason I got a discount. Way to go Alan!!!!!
01-17-2017, 02:50 PM
Originally Posted by guccidude1
Gerry: Are you and I the only guys who bought the Pulse oximeter? Dan from Reno
I bought one and was dissatisfied with its quality. Allan contacted me and offered to do whatever it would take - no arguments there, good service and I'd buy from him again. Instead, I gave it away and replaced it with one that I like from Amazon.
My gripe with it was that its readings didn't compare well to an expensive medical one I've also got. The new one does.
Dave
01-20-2017, 11:28 AM
Originally Posted by erich weaver
Love the almost a 14 and nose job mods, and also make use of the prop wrench. I got the gust lock too but sold it in favor of exterior gust locks. I found it a little bit awkward and more importantly, you have to get into the plane to take it off and then get out again to do your pre-flight. That bugged me. Always great service from Alan.
Erich
Bought the gust lock from Erich.  I don't use it often (most of my flights are lunch hops on calm days) but it's great to have for those overnighters.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
01-20-2017, 01:52 PM
Gust lock
IMHO you don't need the gust lock for the wind as much as you need it to protect your control surfaces from the knucklehead airplane drivers who prop-blast you with their engines at 2000 rpm with no consideration as to who or what is behind them. I always use my gust lock.
~Marc
RV-10
N814RV
2020 Donation Made
