Go Back   VAF Forums > Main > Reviews
Old 01-14-2017, 04:19 PM
rleffler's Avatar
rleffler rleffler is offline
Default Gretz Heated Pitot
My RV-10 has been flying for over three years. I installed the Gretz Heated Pitot. For three years, it has been working fine.
Last Sunday on a twenty minute flight, VFR wx, -10F temp, the pitot melted from the inside. There was no external damage, but from the tip back about an inch, was plugged with the composite material. It appears that the composite material melted, dropped to the end, then solidified.
At this point in time, I'm no longer comfortable with flying with the Gretz Pitot. I can't fathom the world of hurt I would have been if this happened while I was in IMC.
I'll be replacing it with a Dynon Heated Pitot as soon I can get Stein to ship it.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 01-14-2017, 05:38 PM
cajunwings cajunwings is offline
Default gretz
For what its worth I have the Gretz system that came out of my 9 that I won't be using. It has 95 hrs total time and will sell for very reasonable price.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Old 01-14-2017, 05:39 PM
1001001's Avatar
1001001 1001001 is offline
Asking out of ignorance, is there a fundamental difference in the construction of the two units that precludes this as a common failure mode between the two?
Old 01-15-2017, 06:25 AM
rleffler's Avatar
The body of the Gretz is made out of a composite material covering a copper tube.
The Dynon's body is aluminum, making the melting temperature significantly higher.
This is an assumption on my part, since I don't know the melting temperature of the composite material of the Gretz. I just have proof it melted.
Bob Leffler
Old 01-15-2017, 06:31 AM
rleffler's Avatar
Don Broussard
57 Pacer
I appreciate the offer. But at this point in time I have no confidence that another Gretz Pitot wouldn't yield similar results.
Bob Leffler
Old 01-15-2017, 07:24 PM
N661DJ N661DJ is offline
Don,
PM sent.
Dick
Old 01-15-2017, 08:09 PM
Originally Posted by N661DJ View Post
Don,
PM sent.
Dick
Dick: Nothing in PM. Let's try email. Don
cajunwings@cox.net
Old 01-17-2017, 06:01 AM
Electrogunner Electrogunner is offline
Seems to a common thing. I just sold a new gretz to a guy that had his melt. May be an issue with the composite bodied pitots. I sold him the old style metal.
RV10 N620RV
IO540 C4B5
Whirlwind 375RV prop
Garmin G900X
First Flight 2/14/2019
Old 01-17-2017, 10:06 AM
Bob can you elaborate on this? Were other avionics affected?
