Old 01-13-2017, 08:42 PM
Michael Burbidge Michael Burbidge is offline
Default Sky-Tec Starter Intermittent fail to engage
I have a new Sky-Tec starter (149-12LS).
I replaced my starter at my last condition inspection because the old one had a loose solenoid. The A&P that went over my firewall forward had not seen a loose one before and suggested I replace the starter.
Now occasionally the starter contactor clicks but the starter does not engage. If I get out of the airplane and pull the prop through a few times, and then try again the starter engages. It's happening fairly often. Today it happened 300 miles away from my home field. Let me with a sinking feeling.
It's seems like if the prop is clocked just right the starter does not engage.
The old starter had no such problem. So I'm thinking its probably the starter and not something else. i.e. battery or starter contactor.
Does that sound right?
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 01-13-2017, 09:51 PM
Infidel's Avatar
Infidel Infidel is offline
When you hit the ignition, does the starter spin up with that winding noise? If so, I'd suspect the bendix aren't extending into the flywheel. I experienced it twice with my starter and as a fix I lubricated the shaft the bendix travels on. Haven't had a missed starter engagement since.
Old 01-13-2017, 10:01 PM
BigglesRV7A BigglesRV7A is offline
In addition to 'Infidel's' reply, check the power cable connections both ends. I had an issue with mine some time ago and discovered a 'dirty' connection at the starter motor. Cleaned, installed new star washer and good to go.....until I eventually changed out the starter for the NL type. (a whole other story with a number of threads to explain)
Good luck
Greg (2017 VAF dues PAID)
Greg (RV-7A FADEC IOF360M1B, WW200RV)
Old 01-14-2017, 01:13 AM
Janekom's Avatar
Janekom Janekom is offline
A friend had the same here on a brand new RV14 (20 hrs). They swopped the starter and problem has gone away.
Jan Hanekom
South Africa
Approved Person nr 325
http://www.rvbits.com
RV10 - ZU-XOX - (Flying)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Bought back)
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2020 WITH A SMILE
Old 01-14-2017, 04:17 AM
RKellogg RKellogg is offline
Arrow Solenoid - automotive.
Michael, I had same issue with two different low time ST starters, same p/n. Replacement solenoid fixed problem. Found ST difficult to deal with. Apparenly they do not track production by serial numbers and wanted the whole starter shipped back for part replacement. IIRC the actual solenoid is an automotive part, maybe ford crown vic? ST was frusrtatingly hard to deal.with. The solenoid change is easy.
ST eventually diagnosed the solenoid failures to a "rare, unheard of" partial coil failure that gives the solenoid enough force to move the core but not enough force to drive the pinion gear into mesh with the ring gear. On the occasions when the gears align, the reduced force is enough to move the core far enough to close the conactor and it works 'perfect'.... until next time.
The horizon beckons, I must fly.
- Roger
Old 01-14-2017, 12:31 PM
hohocc hohocc is offline
http://www.vansairforce.com/communit...ight=crown+vic
Old 01-14-2017, 02:35 PM
Default Thanks
Infidel, no spinup with winding noise. Just click of the starter contactor.
Thanks for all the suggestions. I will go through the voltage checks suggested by Sky-Tec website and then contact them.
I'm hoping to trade up to the NL version because I have a catto prop and with the new starter have also experienced mild kickback.
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
Old 01-14-2017, 03:27 PM
Michael-
Michael are you able to borrow a new battery? Try it before you replace the starter.
Old 01-14-2017, 06:47 PM
BillL BillL is offline
Is there some reason not to do some diagnostics? Get a VOM and check some hypotheses. Start with voltage at the battery for the baseline, then contractor - move along to the starter. Construct a long cord if you are doing this solo.
Bill
RV-7
Lord Kelvin:
Old 01-14-2017, 07:56 PM
Default Will do...
That is exactly the 3 diagnostic steps suggested on the Sky-Tec website. I plan on doing it this week.
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
