  #11
Old 01-11-2017, 06:33 PM
rolivi's Avatar
rolivi rolivi is offline
Nose Job 2
Lip Skid
Probably will do the gear bearings (all three) this year.
Considering the oil system mods.
And I must say, they are AWESOME when you call for help. I'm mechanically inept and I stripped out a couple bolts on the nose job. They shipped replacements the same day at no charge.
Nothing but praise for them from me.
Rob
RV-6A (Purchased)
2020 Dues Paid, of course
Old 01-11-2017, 07:57 PM
erich weaver's Avatar
Love the almost a 14 and nose job mods, and also make use of the prop wrench. I got the gust lock too but sold it in favor of exterior gust locks. I found it a little bit awkward and more importantly, you have to get into the plane to take it off and then get out again to do your pre-flight. That bugged me. Always great service from Alan.
Erich
Old 01-11-2017, 10:37 PM
gerrychuck gerrychuck is offline
I have
-Nose job
-Skid plate
-Nose wheel bearing mod
-Almost an RV 14 mod (best thing I ever did to my 6)
-Gust lock (really like it)
-Oil filter wrench
-Pulse oxymeter
I think that's it lol. Very happy with the company and the products.
Gerry Julian
Moose Jaw Saskatchewan
RV6A "Second Wind" C-GERZ (born N242UL)
O-360 A1A, Sensenich FP prop
Those who think any system is foolproof greatly underestimate the ingenuity of fools
Old 01-12-2017, 05:24 AM
ShortSnorter ShortSnorter is offline
Default Primer type
Recently installed VS bracket mod.
Is that zinc chromate?
Ryan
RV-14 In-Progress
Build Site
Old 01-12-2017, 07:05 AM
301 high tensile aircraft grade stainless sheets (UNS S30-100).
Old 01-12-2017, 10:20 AM
N743RV N743RV is offline
Default Ten out ot 10 Rating
I've used the following products from Anti-splat:
Nose job
Main wheel bearings
Nose wheel bearings
Air/oil separator with vacuum
Gust lock
EZ Cool Cowl Flaps (2)
Every product has worked as advertized and the support has been very good.
Bob Cowan
RV-7A , Mattituck IO-360 M1B, Hartzel Blended CS Prop,
Old 01-12-2017, 12:07 PM
guccidude1 guccidude1 is offline
Gerry: Are you and I the only guys who bought the Pulse oximeter? Dan from Reno
Old 01-13-2017, 06:14 AM
N282S's Avatar
N282S N282S is offline
Default Best of Antisplataero LLC
#1 Ultimate Gust Lock
http://www.vansairforce.com/communit...mate+gust+lock
#2 Prop wrench
#3 Oil Filter Wrench
Nice work, Alan.
Steve Stucky
Topeka, Ks
N282S - VariEze 500+ hrs
N283S - RV-7 1400+ hrs
KC-135 A/D/E Boomer (Ret.)
Old 01-13-2017, 07:52 AM
grubbat's Avatar
grubbat grubbat is offline
Vlad,
Did you put washers under those bolt heads? Seems like I recall reading somewhere that a washer or oversized washer is needed on the upright portion because of the slots to help spread the load bearing.
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 IO-360 CS, Built and Flying
Aerostar 600A, Family Hotrod
Old 01-13-2017, 08:18 AM
I had the oversize washers then decided to remove them. They require even longer bolts.
