Old 01-08-2017, 06:54 AM
Robert Anglin Robert Anglin is offline
Default Your call
Me too for all the above reasons. Kts. Only one little addition.
The more you fly the more math you will be doing in your head as you go.
It may help you to make a cheat sheet and start getting used to a few conversions. This is one you will know by hart after a while " 1.151" Sm. to Kts.
I find myself even doing it on a road map some times. Hope this helps. Yours as always, R.E.A. III #80888
Old 01-08-2017, 07:17 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Originally Posted by dutchroll View Post
Suffice to say it's a hangover from days long gone by. I did read a great story about the Mooney 201 which apparently was named because it could reach 201 mph in level flight, and "Mooney 175" (in knots) just didn't have the same marketing "zing"! Maybe they should've gone full metric and named it the "Mooney 323"?
The "days long gone by" date back about four decades...
In the mid 1970's GAMA (General Aviation Manufacturing Association) recommended all manufacturers standardize on knots and so most but not all switched (Maule for example still to this day uses MPH calibrated airspeeed indicators).
My 1977 Tiger was made in the first year the factory switched from mph to knots on the ASI and placards.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-08-2017, 07:18 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Another handy quick conversion. For centigrade to fahrenheit, double the degrees centigrade then add 30.
Example: How many degrees fahrenheit is 15 degrees centigrade? Answer; 15*2 = 30, then add 30 which gives you 60 degrees F. While not exact (in this case it is actually 59F) it will be close enough for most of our applications and especially for getting an idea of what the temperature is.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 01-08-2017, 07:26 AM
rzbill's Avatar
rzbill rzbill is offline
Originally Posted by RV7A Flyer View Post
so it's cooler than the arbitrary distance of a statute mile .
So whats arbitrary about 1000 paces of an ancient Italian dude in fighting gear??
Seriously though, I agree with the crowd. Knots.
Bill Pendergrass
ME/AE '82
Old 01-08-2017, 07:43 AM
vetterman vetterman is offline
Default Knots vs mph
I'm not throwing any sand in the gears here as I use both knots and mph depending on the airplane I'm flying, however if you look at the performance specification of every RV model, Vans aircraft (ya the mothership) uses MPH. Go figure
Old 01-08-2017, 08:00 AM
Mach.26's Avatar
Mach.26 Mach.26 is offline
Of course. MPH "briefs" better to buyers
Adam Wright
RV-8 Builder 83611
Old 01-08-2017, 08:32 AM
Beer30?'s Avatar
Beer30? Beer30? is offline
Default 1:60 rule works with knots
1 NM = 6000' is the basis of the 1:60 rule. You're 3 degrees off the localizer at 10 NM from the field. How far off are you (so you can plan your lead point turn)? 3/6 or 1/2 mile, or 3000'. The math also works well for desecent planning. Most of this is unnecessary if we rely on the electronics, but Inkeep the mental math sharp for when the electronics fail.
David
David Dalton
Longmont, CO
RV-7 Complete,
Flies like a dream!
Lifetime VAF Member
Old 01-08-2017, 08:33 AM
Plummit's Avatar
Plummit Plummit is offline
Originally Posted by GalinHdz View Post
What does visibility have to do with speed?
I was referring to the statement that if its aviation, use knots. The FARs make reference to the VFR cloud clearance and visibility requirements for different airspace in statute miles.
-Marc
RV-10
N814RV
2020 Donation Made
Old 01-08-2017, 08:38 AM
az_gila's Avatar
Smile
The knot (actually nautical mile) was only a good guess when it was invented...
1852*m is the length of the internationally agreed nautical mile. The US adopted the international definition in 1954, having previously used the US nautical mile (1853.248*m).[4] The UK adopted the international nautical mile definition in 1970, having previously used the UK Admiralty nautical mile (6080*ft [1853.184*m]).
How the mile changed over time and by country away from the Roman soldier definition is also interesting -
https://en.wikipedia.org/wiki/Mile
Gil Alexander
Old 01-08-2017, 08:44 AM
turbo's Avatar
turbo turbo is offline
i use both from my complicated past. in the plane i use both also. it is easy to go back and forth. 7 mph = 8 knots.
how did they come up with knots? well before we were in the air. the sailors of long ago had a rope with knots in it it. throw it out in the water and count the knots that go out in a specified time.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
