Originally Posted by Tbone
As configured the filter would be too far outboard and not centered in the cowl opening. My thoughts are that the filter needs to sit at least somewhat centered left/right in the opening.
I am curious as to why you have these thoughts? Just trying to understand your thoughts so my question is not meant to say anything is wrong with this.
In my case, when it came to placing the air filter brackets, I concerned myself with where the filter bracket would fit as it related to where the snorkel opening was oriented. I did not just cut a hole in the floor of the air intake floor. I actually cut the floor away and rebuilt it with a bracket in place. It has been 7+ years so some of my memory of HOW is a little sketchy now, but basically I ended up fabricating a replacement for the floor that incorporated the brackets necessary to attach the snorkel and air filter to them. Everything I built is quickly removed with a few screws that are inserted into plate-nuts. I am not sure if any of my previous posts show pics of this bracket arrangement. I will try to see if I have any pics that I may be able to post with this detail.
