Vertical card compass compensation
Is it possible that the 8 degree or so panel angle makes it more difficult to swing a VCC? In my case it's a PAI-700 in the panel, away from big power, no difference engine running, non running, a smidge (a twitch, 2 deg?) when transmitting. I can compensate N-S, but E-W I'm way out - 15 degrees or so. It's a tip up, so no steel. Brass screws.
Full disclosure, I might have over-adjusted the compensation elements at some point - could I have permanently damaged it?
Thanks, Rick
Rick
RV-9A N183RC/90432: tip-up, O320H2, Ellison, Dynon D180, CPi2, Sen GA, at KLPR
RV-8 83718, wing kit, tanks done, with a four year plus plan - on hold due to home move
2011-2020 VAF contributor
