Old 03-23-2007, 09:47 AM
mknight mknight is offline
Question wing tip VOR antenna?
Has anyone put in the wing tip VOR antennas from Vans in a RV7A? I wondered about going around the light wells. The instructions call for a 28" run at the leading edge glassed over. Sugestions! mnight@citlink.net
Old 03-23-2007, 10:12 AM
frankh's Avatar
frankh frankh is offline
Default Forget it!
At least this was my experience, the VOR CU foil didn't work worth a darn...Certainly not good enough for IFR work.
I almost went with a cat whisker but couldn't bear to cut holes in my painted airplane so I went with an Archer with some reluctance.
Wow what a difference, it works great!
Frank 7a
Old 03-23-2007, 12:16 PM
AltonD's Avatar
AltonD AltonD is offline
I am not familliar with the Archer. What does it look like?
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 03-23-2007, 12:46 PM
Rick6a's Avatar
Rick6a Rick6a is offline
Here in the Archer VOR antenna mounted in the wingtip of my 6A. It has performed flawlessly.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 03-23-2007, 12:56 PM
Sam Buchanan's Avatar
Sam Buchanan Sam Buchanan is online now
been here awhile
Details of the Archer antenna in my RV-6:
http://thervjournal.com/sportcraft.htm
Sam Buchanan
RV-6
Fokker D.VII replica
Old 03-23-2007, 02:55 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default Ditto what Rick6A said
Not only flawlessly, but the best VOR reception I've ever experienced. Caveat: I'm using a Garmin SL-30 which is known for excellent reception to begin with.
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 03-23-2007, 06:31 PM
tc1234c's Avatar
tc1234c tc1234c is offline
I have the Van's wingtip antenna on my right wing and Archer marker beacon antenna on my left wing. With SL30 and GMA340 (with marker beacon receiver) the reception is very good (at least for my purpose). I did several practice ILS and one actual ILS. There is no problem picking up distance VOR neither. Installation is very easy.
Ted
http://tc1234c.googlepages.com/
RV9A, O320D2A, FP, 127 hrs
Old 03-23-2007, 07:07 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Wiring routing
I know that Bob's instructions that come with the Archer antenna are quite specific regarding how the wires in the wingtip should be routed with respect to the antenna.
However, it seems to me that the while the instructions make a lot of sense for the old style wingtip with the nav lights mid way down the side of the tip, they don't make a lot of sense for the new style tip (on -7's anyway) with the lights in the forward corner.
It it would very easy to place the VOR antenna in the aft 2/3's of the tip and keep the nav/strobe wires well clear of the VOR antenna. It would be a simpler and cleaner installation.
Is anyone else using this alternate approach to installing the Archer antenna and if so, does it work well?
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Jacksonville, FL
Old 03-23-2007, 08:32 PM
frankh's Avatar
Default Yes
Do it juat as you describe, works great
Frank
Old 03-24-2007, 05:22 AM
Neil Neil is offline
Default DIY
Why would you pay good money for an antennae like this. Have built several similar antennae designs- for next to nothing and they work perfectly in senstivity tests. Build a plane? Surely you can put together 4 pieces of aluminium ?
