12-26-2016, 03:37 PM
WD-630-1 Nose Wheel Fork... Cracks in the Welds
12-26-2016, 03:58 PM
CRacks
Wow ! Good find . Curious from one of the welding pros on what caused this
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
12-26-2016, 04:00 PM
VAF Moderator
Darn, I first though there is now way this could crack but after looking at the rest of the pictures I agree it looks like the weld is cracked. Time to call Vans on Tuesday. Gonna check mine too!
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993 SOLD
12-26-2016, 05:07 PM
There was an SB on checking for cracks in nose wheel forks some time ago. However that SB is not about cracks in the weld but cracks at the bend. Not sure if this pertains to the later version, but a good idea to check anyway. Read here:
https://www.vansaircraft.com/pdf/sb96-09-1.pdf
12-26-2016, 06:47 PM
Cracks in the weld
What I see here is typical embrittlement of filler rod vs the base metal. It's common when the filler rod and base metal have different numbers. It's kinda like trying to weld 2024-T3. My suggestion is taking it to an experienced aluminum TIG welder and have it rewelded using 5606 filler rod with a lot of heat on a square wave machine. I would bet Rick Robbins of Robbins Wings could rewelded it and not crack again. Vetterman
12-27-2016, 07:26 AM
He is calling Van's today to inform them. I think he is planning to purchase a new fork to get back in the air.
12-27-2016, 06:44 PM
He has a new one on the way. Van's requested he mail this one back to them for an investigation....
12-27-2016, 07:46 PM
Cracks down each side of every weld???
I do expect it to be something other than cracks.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
12-27-2016, 08:31 PM
Anyone run a dye check on it to see if they are actually cracks?
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
12-28-2016, 05:47 AM
This can be a common issue if the wrong filler rod was used. Larry commented on that above and other examples are out there on the web.
These are not traditional fatigue cracks that normally would run right down the middle.
Maybe Van's will post their results after they do their dissection....
