Old 12-23-2016, 01:40 PM
Dugaru's Avatar
Dugaru Dugaru is offline
Default Question about a melting strobe lens...
Hi all:
My new-to-me RV-9A, N929JA, is in the barn, so now I've got the full-time grin, and I can stop reading the classifieds.
The downside for everyone else is that I obviously have to start bugging you guys with my questions.
Item 1: My wingtip strobes seem to be generating too much heat for the clear plastic covers. Kind of hard to see in the attached photo, but the lens has actually gotten wavy to the touch right over the strobe.
Given that I'm a CBWLS (cheap bast-rd with limited skills), what's the easiest/cheapest fix for this?
Thanks!
N929JA, 2007 RV-9A
Based W96: New Kent International Aerodrome
(near Richmond, VA USA)
2020 Dues Paid
Old 12-23-2016, 03:22 PM
flynwest flynwest is offline
Default melted lens
Don't turn the lights on until you are in the air. That is the way to not melt them. Order new lenses from fan not a big deal to cut to fit with good scissors.
Horse Power is good, more is better and
Too Much is Just Right
RV 8 Super charged Barrett IO-390
Dues paid 2020
Dan "Nordo" West
Old 12-23-2016, 04:24 PM
Infidel's Avatar
Infidel Infidel is offline
I recently saw a -6 model and the builder drilled an intake hole and an exit hole in the lens. Only figure I could muster was for cooling or fogging?
Old 12-23-2016, 04:45 PM
Bruce's Avatar
Bruce Bruce is offline
And you can move strobe back a couple of inches.
Can make plated out of .032 and polish
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2020 DUES PAID
Old 12-23-2016, 09:56 PM
rapid_ascent rapid_ascent is offline
Yep. I would make a new reflector for the strobe and move it back so that it isn't so close to the lens. Test it first with the messed up lens then if it is ok order a new lens. 1/8" reflective acrylic is available for Home Depot so it should be pretty simple to make a new one using the old one as a template.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 12-24-2016, 05:58 AM
Lenny Iszak's Avatar
Lenny Iszak Lenny Iszak is offline
Default replace with LED strobes
I've built the same exact nav/strobe setup, and it also melted my wingtip lens within just a couple of hours of use. I had a QuickStrobe ballast in each wingtip, and i think the pattern in that has the strobe on for way longer than a regular aviation pattern does, overheating the bulb.
I ripped out the strobes and replaced them with Feniex Cannon LED strobes. The are $70 each, very bright, put out no radio noise and fit in the same hole.
You can find them here:
https://www.amazon.com/Feniex-Cannon.../dp/B00HV4NMW6
Lenny
Old 12-24-2016, 06:53 AM
thinkn9a thinkn9a is offline
Default Cheapest,....
I'd leave it and see how it goes..
Mine had a bit of softening/ curve early on,...but no further issue in over 500 hrs.
Unless you are going for perfect,...buy avgas instead
Wallace & Marietta Goodloe
9A -QB
N211LV
Phase 2 has started!
Thanksgiving time, is dues time for us
Old 12-24-2016, 06:59 AM
Electrogunner Electrogunner is offline
Lenny
Lenny,
Would like a little more info on these. How long have you had them? Pics of the install. How does the output compare?
Joe
RV10 N620RV
IO540 C4B5
Whirlwind 375RV prop
Garmin G900X
First Flight 2/14/2019
Old 12-24-2016, 08:47 AM
Default LED strobes
Joe,
I've had them on for about 250 hours. It was an easy replacement. I mounted the driver box onto the outboard wing rib and connected the wires. They have multiple patterns and a sync wire. If you connect the sync wires together from both wingtips they will flash simultaneously. It puts out a bunch of power. Controller mentioned a couple of times that he can see me way further out than other planes. That's my scientific assessment.
Specs say it's got 12x4W LEDs and at max power it puts out 2400 lumens.
After trying several LED drivers for the Nav lights, and having all of them trash the radio, except one, I was worried about radio noise, but this thing is engineered well, radio is silent.
Haven't changed the wingtip lenses yet, they are still melted just like Doug's.
Lenny
Old 12-24-2016, 09:04 AM
terrykohler terrykohler is online now
Default You Don't Need the Reflectors Under the Lights
if the lights meet the brightness spec., the reflectors are pointless. By having these under the lights, they move the heat source closer to the lens, which is likely your problem. Just an uneducated opinion.
Terry, CFI
RV9A N323TP
