Old 12-23-2016, 08:10 AM
springer springer is offline
Originally Posted by N804RV View Post
But, I'm really curios to know if there are any others out there flying IFR behind behind a big single display, instead of the airliner style full redundancy.
There are thousands of military fighters with nothing more than this and a tiny "peanut" stby attitude indicator.
Jim
RV-4 '88-'09 Built & Sold
RV-8 Purchased
Old 12-23-2016, 08:27 AM
KatieB's Avatar
KatieB KatieB is offline
I'm planning for an IFR "capable" system. It seems like all the glass sales promotions are aimed at dual and triple redundancy. Yet, most IFR "capable" C-172s with vacuum systems do not have all this redundancy. And, they've trained how many thousands of instrument pilots?
Old IFR panels may look like dinosaur-poo but they do have a lot of redundancy because the 6-pack is broken into 3 different systems. If the vacuum system (attitude, heading) goes, you use your pitot/static instruments, electric turn/bank and compass to stay upright. If the pitot/static goes, you use your vacuum gyros and electric turn/bank. If electric goes use the other two. In the EFIS scenario, all your instrument systems are electric and they are all in one box, so a reliable, independent backup to keep the blue side up is important.
Katie Bosman
RV-3B sold, but flying!
Next project: ???
Builders gonna build...
Old 12-23-2016, 09:01 AM
vfr800 vfr800 is offline
Default Modern redundancy
In a prior RV, we went with a similar approach (though I wasn't IFR trained at the time) & it worked nicely overall. One big 8.4in GRT Hx screen with dual AHRS, plus a Dynon D10a for back up provided dissimilar redundancy. You could select AHARS 1 or 2 for that single screen. Though if that one display failed, now you lost two sources at once.
Nowadays, I think a single big screen (even without dual AHRS), a different brand/software back-up (think G5, GRT mini, Dynon 10a), plus an iPad having a separate source of attitude info (Stratus 2/2S) gives you a tie-breaker and enough redundancy. Many fly with an iPad any ways for multiple reasons, so it's not an added equipment cost for them/me.
Even if some rare emergency destroys all electronics on board, this could provide basic attitude, altitude and ground speed to get down safely. Starting a flight fully charged, the battery life in the Stratus and iPad doesn't require keeping them connected to power except for the longest of XC days (more than 6-8 hours).
More commonly, if one brand/model of primary flight data acts up, it gives you sufficient independent options to compare and decide which to believe.
One downside -- I didn't like how I would lose the display of some desired information when displaying PFD, nav and engine information on the one screen. Specifically, if I remember correctly flap and trim indications come to mind. First world problem, I guess... I had to look over my shoulder to see flaps. Something to consider & assess with your specific model in mind for only one screen.
Just my thoughts with the modern tools readily available to us these days.
Ryan M
VAF donation next due June 2021
(Exempt but worth it!)
Prior partner in RV-9a & RV-10
Now flying RV-10 #40515
Old 12-23-2016, 09:28 AM
runt runt is offline
Default mis-compare
The mis-compare function is the key.
I would assume it takes 2 AHRS talking to the same system to get the mis-compare function. Is this correct? A single AHRS would simply give the display (and autopilot I imagine) bad info until it died. Could be wrong as I'm new to these systems.
It seems to me 2 AHRS for a single screen and a independent stby would cover the tie-breaker problem. The question would be - is the backup AHRS being monitored when it isn't in use. I imagine so but not sure.
Old 12-23-2016, 09:36 AM
Walt's Avatar
Walt Walt is offline
Most of this was discussed in this thread I started some months ago...
http://www.vansairforce.com/communit...d.php?t=139717
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 12-23-2016, 09:47 AM
Yes, it was covered there. Looks like Garmin does monitor the background system. At least in the system mentioned.
Thanks for the link Walt.
Old 12-23-2016, 10:05 AM
Originally Posted by Dorfie View Post
[ Where does the straight and level information comes from that will drive the AP? Does the AP have it's own independent AHARS?
Johan
Short answer = YES for the TruTrak product.
Old 12-23-2016, 10:55 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
Trio Pro Pilot has it's own MEMS gyros and static, pitot ports, so I reckon it's a YES for them, too.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD reserved - under construction
donating monthly to the VAF - thanks, Doug
Old 12-23-2016, 12:39 PM
Walt's Avatar
Just my opinion but honestly I don't think there's any real comparison between an inexpensive 'gyro' found is some AP's and a true ADAHRS such as the Garmin GSU25/73.
Old 12-23-2016, 02:53 PM
Originally Posted by RV8JD View Post
Yeah, but they have ejection seats!
This is not a joke. I have an old copy of an air force training manual; it says to do exactly that (eject), for loss of instruments or even if it's just your brain that's spinning.
