12-20-2016, 05:49 PM
Originally Posted by jbDC9
For this SB, is there a serial number range or perhaps a a kit "vintage" date? I checked my -8QB this morning, bolts were factory installed. Which is good I guess... 2004 QB fuselage, been flying for 10 years.
Me too. I confirmed today my late 2008 QB (delivery date of fuselage)also had the bolts installed.
John Mastro
RV-8
12-21-2016, 06:19 AM
The earlier (pre-2006, pre-punched) 8's came with factory rivets installed in these holes. I called vans and they said this was ok.
Tracy Willingham
RV-8
Powered Paraglider
Pitts S2B- sold
Chattanooga, Tn
Dues Paid
12-21-2016, 08:53 AM
Center Section Bolts
Be careful with this assumption. My 2003 QB had the open holes that needed the fasteners installed.
Skylor
RV-8
12-21-2016, 10:59 AM
My 2002 kit
had the open holes. I guess it is a pre-punch kit, it for sure is not a quick build. I am noting a lot of variability in the reports from the field here.
12-21-2016, 01:17 PM
Does this apply to "A" Models
The SB does not mention RV-8A but it also does not say that it does not apply. My guess is that it does not apply (NA) since these holes are used to attach the main gear weld-mounts.
I want to confirm so that I don't make a needless compliance entry into my aircraft records.
Cheers
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
12-21-2016, 01:24 PM
Long Reach Wrench
If your wings are off you can make the wrench I mentioned above to reach the bolts. Here is the kit log entry with a picture.
http://www.mykitlog.com/users/displa...=71255&row=185
Cheers
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
12-21-2016, 03:36 PM
Cheers
The assumption is that if an RV-8A hasn't lost its main gear legs that the bolts are likely installed.
If it applied to both it would say RV-8 and RV-8A
Scott McDaniels
Hubbard, Oregon
12-22-2016, 09:09 AM
Super Moderator
Thanks for posting this Tracy. My -8QB kit was delivered March, 1999. It has rivets installed, no bolts. I spent about three hours going through the SB, my drawings, and a special trip to the hangar to inspect my spar looking for these bolts. Obviously no luck finding the bolts or empty holes since they weren't a part of the spar design at that time. So why the discrepancy on dates and results as reported in this thread? That's a mystery.
P.S. If it helps my serial number is 80898, first kit order in December 1998.
Chris
Chris Pratt (2020 VAF DUES PAID)
RV-8 Flying, 850+hours
N898DK
Lycoming O-360-A1A, Hartzell CS
52F (Northwest Regional, Aero Valley, Whatever, TX)
Reason: Update SN
12-22-2016, 09:55 AM
Are there possibly some cherry max rivets that could be used here? I have open holes. Obviously missed this step in the manual and am lothe to drill holes to access the nuts.
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
12-22-2016, 11:09 AM
I checked mine today (QB) about 6 years old and the bolts are missing, i also checked a slow build in the hangar thats about 10 years old and the 4 outside bolts were missing, so its not just QB kits affected!
