12-19-2016, 10:34 AM
Another Longeron
Originally Posted by Mel
I disagree that this is common. I've inspected a lot of RVs over the last 35 or so years and I find this rare. Yes, I've seen it, but not often.
Mel,
Doesn't the six have another longeron in this area and access on only one side, plus a smaller access panel as well?
Perhaps this is why the -6 is superior to the -7 ???
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
12-19-2016, 11:07 AM
OK, Here's my "guess"!
Originally Posted by Bob Martin
Mel,
On the -4 & -6, the center "J" stiffener continues all the way to the tail at the bottom of the inspection panel.
The -7 was designed after the -9. The -9 was not designed with a tailwheel version in mind.
Perhaps the designer didn't think that last bit of stiffener was needed on a tricycle. When the -7 came out, this was simply overlooked
My $.02!
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
12-19-2016, 11:08 AM
Mel,
Yes, it looks like the downside to the larger -7 access panel is the loss of the middle J-stringer in the aft most fuselage bay compared to the -6 models.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
12-19-2016, 11:19 AM
Another suggestion:
Any time you add an "angle" stiffener to a skin, be sure to secure it to the bulkheads at each end, either by a joggle or a shim. Without this security the skin will eventually crack at the ends of the stiffener.
12-19-2016, 12:03 PM
Originally Posted by Ironflight
To me it looks like a classic case of side-loading the tailwheel - it falls off the pavement and gets caught on an edge, or the two bolts that hold the socket to teh spring shear as the tail is being swung around and it falls off an edge. Either way, the tailwheel itself comes to a sudden stop while the fuselage is still trying to swing, and you put a slight kink in the fuselage structure. I've seen it on a couple airplane's, and both have had a sudden tailwheel stop event.
Just one possibility.
Paul
Look at the bottom of the rudder fairing. If there is not indication of contact damage from the tail wheel, then the scenario Paul described above is likely the cause.
N477RV (the RV-7 owned by Van's and used by Mike Seager for transition training) has spent its entire life based on a grass runway airport. It is just a few hrs shy of 4800 hrs T.T. and has had nothing like this occur (not to mention all of the plopped in landings it has endured during training).
The inertia of the induced by the tail swinging can induce huge twisting loads on the tail spring mount if the tail wheel comes to a stop suddenly.
Scott McDaniels
Hubbard, Oregon
12-19-2016, 12:07 PM
When you do this, you'll need at least 2 rivets per flange. Otherwise it won't carry any real load.
From one of my structural engineering texts, Bruhn's "Analysis and Design of Flight Vehicle Structures."
Dave
12-19-2016, 12:59 PM
Sorry...
OK, looking at all the posts since this morning it seems that I gave incorrect informations.
I apologize if what I wrote was not good.
However it makes sense to me to put a reinforcing angle at that location, with all the precautions that others have stated.
Alain.
RV7 (F-PRVZ), Tip Up, Aerosport IO-375, Dynon Skyview, VP-X, Day VFR.
Flying since June 2017.
12-19-2016, 02:12 PM
I agree with Paul's theory that the tail wheel was abruptly side loaded. Looking at that skin, I'd check further for possible internal damage.
The things I would check is; bolt holes in F711 & F712 bulkheads are not stretched, WD409 tail spring weldment wasn't cracked, F711 & F712 bulkhead rivet flanges were not stretched out, lower J strip not buckled.
The ripple in the skin has taken a lot of rigidity away from that section of the fuselage, stiffeners (more than one) might restore most but not all to that area.
First off- I'd be phoning the mothership for their suggested course of action.
Ralph
built a few RVs, rebuilt a few more, hot rodded some, & maintained/updated a bunch more
12-19-2016, 02:52 PM
My $.02!
Can somebody post a photo of this area or the plans of a 4 or 6?
Don
12-19-2016, 02:53 PM
Tailwheel side load
I have seen this exact deformation in the same location in an RV-8 that was ground looped. As the plane veered off the runway, the Tailwheel got caught in muddy grass while the fuselage continued to swing around. The rear part of the fuselage was buckled slightly where the Tailwheel spring attaches to the two rear fuselage bulkheads. Repair involved replacing both rear bulkheads (they both are double bulkheads), and the bottom rear fuselage skin. The top flat fuselage plate, under the horizontal stabilizer, may also be deformed and need to be replaced. It will still be difficult to remove the bump on the side fuselage skin. The bump can be minimized with an aluminum angle on the inside as suggested by others.
Dan Miller
Reason: Added info
