Old 12-14-2016, 09:34 AM
Saville's Avatar
Saville Saville is offline
Have a drawing or specific dimensions?
Here is one set of dimensions - be sure to look at the second drawing and not the first:
http://www.kit-plane-advice.com/fron...rol-stick.html
I would need to make measurements to be certain that works in my -8
The web page owner cut and welded his stick. Not sure I'd like that.
That's only one set of dimensions I've found.
This thread shows a ruler next to a bent stick near the top of the thread.
Variations in people's -8's as well as grip differences being what they are, I'd imagine each customer would want to make measurements and also tell you which grip they are using.
Flying RV-8 N880BC
2019 Dues - happily paid.
Old 12-14-2016, 11:42 AM
BHunt BHunt is offline
Originally Posted by Saville View Post
Link to the thread, inside the thread. Its a VAF Inception.
Scooby
Harrumph!!
RV-8 IO-390 N788MT
Old 12-14-2016, 11:50 AM
mill2978's Avatar
mill2978 mill2978 is offline
Thumbs up I'm interested as well
I'd like a bent stick.
I ordered the bent RV14 stick from Tosten it's not arrived yet but my intent was to see if I could adapt it to my 8. A purpose bent part would be much easier.
Aaron Miller
RV8 N127KT - First Flight October 16, 2018
http://www.mykitlog.com/AaronMiller/
Old 12-14-2016, 12:16 PM
N329JR's Avatar
N329JR N329JR is offline
What is the tube OD and wall thickness?
RV-3B My RV
RV-6 (Dad's RV)
RV-8 Empennage 95%, Wings 95%, Fuse 2%
2020 VAF Gladly Paid
Old 12-21-2016, 08:53 AM
frankd's Avatar
frankd frankd is offline
Default Tosten Stick
I ordered one as well. It is 7/8 in. The plan is to cut the base of the stock stick, and use a slip joint with a pin similar to the rear stick.
Frank Dombroski
NJ KSMQ & FL KCRG
Chronic Offender RV-10 (3), RV-8 (2), RV-7 (2), RV-12
RV-8 2.0 N84FD 2020
Extra EA400 N72JV
Old 12-21-2016, 09:19 AM
jbDC9 jbDC9 is offline
Youse guys that are trying the Tosten stick, please keep us updated here on how it works out; I'd love to have a bent type stick in my -8, but it appears the only way I could realistically do it is to take my current stick to a welding shop to have it cut and new tubing welded in to reshape it...
John Bixby
RV-8 QB sn 82030 - 1750 hrs
O-360-A1D/CS/Pmags
Houston, TX
Old 12-21-2016, 10:54 AM
Veetail88's Avatar
Veetail88 Veetail88 is offline
I've always wondered why no one miter cuts the stick and welding back together with an offset in it. I assume it's made out of aircraft grade tubing and a certified welder should be able to do a fine job with it. Missing something?
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 12-21-2016, 11:02 AM
Saville's Avatar
This web page describes exactly that:
Flying RV-8 N880BC
Old 12-21-2016, 08:44 PM
Blain's Avatar
Blain Blain is offline
Default Roll your own
Pack it with sand, cheap pipe bender. No cuts or welds.
Blain
R-22 sold.
RV-8 AW Cert 02-09-17
N82 Sierra Tango
Avatar courtesy of AircraftStickers.com!
Dues gladly paid thru Nov. 2020(my reminder)
Old 12-24-2016, 09:17 AM
akarmy's Avatar
akarmy akarmy is offline
I have a bent stick that I tried out for a few hours. I could not get the Tosten grip to work with it as you need to cut the stick down too much to fit the mounting hardware in, and then the hardware is halfway in the middle of the top bend. I had to go with a different grip that just slipped over the stick. You might be able to make it work with a cut and weld setup if you measure carefully.
Andy Karmy
Covington WA
RV-8 - Flying!
RV-9A - sold
Dec 2019 Paid
