Old 11-16-2016, 12:48 PM
Capt_Riney Capt_Riney is offline
Default Need Help with Aileron Pushrod Riveting
I'm having a devil of a time with riveting the rod end bearings to the W818 aileron pushrod (the 0.5" steel tube). For starters, the AN470AD4-12 rivets seem too long to me, but that's what the plans call for. Everytime I try to drive the rivet the shop end keeps rolling over on me cause I can't keep the bucking bar exactly square on the rivet. I've got everything secured in a vice so not sure what else I can do. The rivet is too long to try and squeeze. Any ideas?
Mark Rinehart
RV7 Quickbuilt kit
Old 11-16-2016, 01:06 PM
Bavafa Bavafa is offline
This was a hard one for me too as it kept bending. I used a bench vise to set them and that gave me a much better control and was able to do all of them without much issue. I think some folks weld them on. Hope this helps.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 11-16-2016, 01:10 PM
IMHO go ahead and try one size smaller. This rivet is 100% in shear so overdriving a slightly short rivet is okay. Just be sure it swells to completely fill the holes.
Old 11-16-2016, 02:35 PM
mill2978's Avatar
mill2978 mill2978 is offline
Default Weld them
After trying to rivet them and finding myself in the same spot I took them to a local welding shop. They welded the rod ends in place, they look much better and there are no clearance issues with the rivets where it exits the rear spar.
Aaron Miller
RV8 N127KT - First Flight October 16, 2018
http://www.mykitlog.com/AaronMiller/
Old 11-16-2016, 04:10 PM
Chino Tom's Avatar
Chino Tom Chino Tom is offline
Wink
+1 IMHO
Tom Prokop
Chino, CA
RV-8A,180/CS/Carb, AFS 4500 EFIS/EMS
RV-6, sold, 820 hrs of fun.
Old 11-18-2016, 09:58 AM
Thanks everyone for the advice. I'm having them welded.
Mark Rinehart
RV7 Quickbuilt kit
Old 12-06-2016, 10:01 AM
Charles in SC Charles in SC is offline
I welded mine as well. Keep in mind that the tube should be oiled inside for rust prevention after welding. This is what I did. Drill a 1/8 inch hole and use a rivet to fill the hole after oiling. Do not get to anal about what kind of oil to use, most anything will work. Sqwirt in a tablespoon, slosh it around and let the extra drain out of the hole overnight, then plug the hole with the rivet. If you want to get technical Spruce sells tube oil but I think it is just linseed oil.
RV 7
Old 12-07-2016, 02:00 PM
tgmillso tgmillso is online now
This is a common issue and there are a number of posts on the forum addressing it. The standard fix is to grind the rivets down to 11.5 length, then they will set perfectly. Some even finish the squeeze using AN470 shop head die on the factory head to give both ended a rounded finish. The easiest way to grind the rivets down is to drill a #30 hole through a piece of 1/8" material so you can hold it nice and square, put the rivet in and hold it against your disc sander, then finish it on the scotchbrite wheel. Only takes a second. If you use your rivet gauge 12 is just too long, so they should be expected to bend over. You will find that throughout the build sometimes the rivet callouts are not exactly on the money, so be prepared to have your rivet gauge handy. Just grinding some rivets down a bit is a heap easier that setting up for welding, at least from my experience.
Tom.
Old 12-07-2016, 06:38 PM
g zero g zero is offline
Default Rivets
Saw a post on FB / RV Nation , the builder used pulled rivets . When I pointed out he might want to check the plans he said " I've built 4 RV's this way ,it's ok "
Not a place for for the wrong /substandard hardware !
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
Old 12-07-2016, 10:46 PM
bob woods bob woods is offline
Default Aileron pushrods riveting
Mark
If the rod end is hollow ,fill it with micro/epoxy. After cure drill hole. Rivet will not bend. This is what Lancair does. Bob
