Old 11-30-2016, 02:52 PM
Tiger 74's Avatar
Tiger 74 Tiger 74 is offline
Default Hot CHTs?
Got hot CHTs?
Fit these, they lowered my CHTs by 30 degrees with no noticeable loss of speed and look **** sexy too!!
http://s58.photobucket.com/user/dont...tml?sort=3&o=7
http://s58.photobucket.com/user/dont...tml?sort=3&o=6
http://s58.photobucket.com/user/dont...tml?sort=3&o=5
http://s58.photobucket.com/user/dont...tml?sort=3&o=4
Old 11-30-2016, 03:36 PM
DanH's Avatar
DanH DanH is offline
Lowered 30 from what original temperature, at what OAT?
Dan Horton
RV-8 SS
Barrett IO-390
Old 11-30-2016, 03:47 PM
g zero g zero is offline
Default CHT
Dan do you ever feel that you are beating a dead horse when it comes to high CHT's and Hot Oil ? You have a lot of patience 😩
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
Old 11-30-2016, 04:23 PM
Marc Bourget Marc Bourget is offline
Fell like he's beating a dead horse ???
Maybe if he had a God Complex.
Good Guys value themselves on how they can help others be the best that they can be. I see this in Dan by the effort he expends and the intellect he lends to those tasks.
Way to go, DanH !!
Old 11-30-2016, 05:31 PM
Default CHT
Dan definitely knows how cooling works . And he definetly cringes at bandaid cooling fixes like louvers.
I'm just surprised he doesn't get tired of trying to educate builders that do the same stuff over and over .
Rv8
N 666 TA
2017 donation paid
Old 11-30-2016, 09:15 PM
Tiger 74's Avatar
Thanks for the friendly words guys! Sorry if I have offended the purists!
CHT temps were up around 410-415 F oil up to 210 in climb.
Have Showplanes cowl, 10:1 Pistons on a Superior IO360, James plenum chamber (modified to fit and seal properly), standard Vans oil cooler.
OAT was around 70F at the time of testing.
P-Mags were set to 25c.
Everything looked to be set up right, but the temps were too high.
I added the louvres to get the problem solved during flight testing to get the permit to fly.
It worked. CHTs now steady and balanced at 370-380 in climb, oil no higher than 180.
I saw no noticeable reduction in speeds, so drag penalty seems low. Why not keep these on permenantly? They don't look too bad (pretty good actually).
Old 11-30-2016, 10:17 PM
Bevan Bevan is offline
Are the louvers fixed or can they be closed?
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 12-01-2016, 02:41 AM
Tiger 74's Avatar
They're fixed
Old 12-01-2016, 04:09 AM
N941WR's Avatar
N941WR N941WR is offline
...P-Mags were set to 25c.
With the jumper in, the P-mags are set to 26.2* BTC when timed to TDC.
If you programmed them, with a -1.4 offset, then you are at 24.8* BTC.
On an engine with a tight cowl (Show planes or Sam James) and high compression pistons, dropping the timing that 1.4 degrees can make a big difference without a lose of power. In fact, as you raise your compression ratio, you should move the timing event closer to TDC.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-01-2016, 07:00 AM
Toobuilder's Avatar
CHT temps were up around 410-415 F oil up to 210 in climb...
Everything looked to be set up right, but the temps were too high...
I saw no noticeable reduction in speeds, so drag penalty seems low...
What did the temps do in cruise? A transient temp of 415 is not out of line, but at 70 OAT should be better, admittedly.
Do you have the bypass ducts on #3 and #1 to address the well known "zero fin depth issue"? Also, did you tune up your intercylinder baffles to seal ALL air leaks, or are they just installed staight out of the box?
Ignition timing is also a big factor.
Concerning the drag penalty, adding a massive increase in outlet area certainly hurts you. There's no way around that. Or more to the point, if you missed some of the details mentioned above, you have a lot of air running through the cowl that is not contributing to cooling, and THAT is where the drag is.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
