Old 11-29-2016, 05:10 AM
s10sakota's Avatar
s10sakota s10sakota is offline
Default Fuel line firewall fittings
I would be interested to see how you guys pass the fuel line through the firewall. Do you use the blue aluminum AN fittings or Steel fittings?
Mark Pensenstadler
1962 Piper Cherokee 160
2003 RANS S-10
2011 RANS S-6S
2011 Vans RV-7
2015 Zenith Cruzer
1962 Mooney M20C
2019 KITFOX Super Sport
Old 11-29-2016, 05:19 AM
Auburntsts's Avatar
I used steel.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 11-29-2016, 05:24 AM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
I used steel for all of the fuel line connections fwf.
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Old 11-29-2016, 05:25 AM
s10sakota's Avatar
As a follow up question: if you used these, either alum or steel, what washers did you use? I didn't see any washers listed on AircraftSpruce with the fittings, and I don't really want to use cheap Home Depot washers.
Mark Pensenstadler
2003 RANS S-10
2011 RANS S-6S
2011 Vans RV-7
2015 Zenith Cruzer
1962 Mooney M20C
Old 11-29-2016, 06:17 AM
snopercod's Avatar
Default AN960 washers
Originally Posted by s10sakota View Post
...what washers did you use?
I used steel fittings, standard AN960 flat washers, and steel AN924 nuts. One thing I would like to mention is that in order to keep the bulkhead fitting from spinning, you will need will need a backup wrench on the back side of the fitting. Be thinking ahead about how you are going to get a backup wrench on the back side while you are torquing the B-nut on the front side. Also, if you are going to install sound insulation on the aft of the firewall, that can block access. Like they say, PLAN AHEAD
(2020 dues paid)
Old 11-29-2016, 07:34 AM
DanH's Avatar
DanH DanH is offline
Don't apply sound insulation to the cabin side of a firewall. Doing so creates a flame transfer system, defeating the reason for having a firewall in the first place.
Dan Horton
RV-8 SS
Barrett IO-390
Old 11-29-2016, 08:13 AM
Toobuilder's Avatar
+1
Thanks largely to your "foot stomping" of this issue Dan, I have spent considerable time scraping the foil and foam insulation off my Rocket (applied by the builder, not me).
I also did a burn test on the remnants and WOW! what an eye opener!
Not only did it burn readily, but it produced enough acrid smoke that I almost passed out watching it burn in the yard. Even without fire, I would almost certainly been overcome immediately in an enclosed cabin.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 11-29-2016, 09:44 AM
rapid_ascent rapid_ascent is offline
I know some will say no need and that I unnecessarily added weight but I made my doubler out of stainless. I don't want the aluminum spacers melting and the fitting becoming loose. I also plan the run stainless tubing back to the fuel filter.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 11-29-2016, 10:20 AM
Here's the requirement for certified airplanes:
"23.1183 Lines, fittings, and components.
(a) Except as provided in paragraph (b) of this section, each component, line, and fitting carrying flammable fluids, gas, or air in any area subject to engine fire conditions must be at least fire resistant...."
There's considerably more to it than this excerpt.
Dave
Old 11-29-2016, 11:32 AM
snopercod's Avatar
Default Flame Retardant per FAR 25.853a Appendix F, Pt1
Originally Posted by Toobuilder View Post
I also did a burn test...
That was prudent since you didn't know what the original builder used. The "Super Soundproofing" that ACS sells is flame retardant per FAR 25.853a Appendix F, Pt1. Whether that's good enough, I don't know (and hope to never find out). All I do know is that without the soundproofing, ATC was unable to reliably hear my transmissions due to the high cabin noise.
(2020 dues paid)
