Old 04-20-2014, 05:24 PM
JDA_BTR JDA_BTR is offline
Default Elevator Spar to Tip Assembly?.
Mounting the elevator spar to the right and left tip assemblies. Not sure if the spar flange goes over the inboard tip assembly flange or vice versa. the flange of the spar is thicker, so I think it goes over the top and the inboard tip assembly flange goes under?. But I can make it go either way. The drawings don't clearly show it?.
How did ya'll do it? Spar flange on top or inboard tip assembly flange on top?
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 04-20-2014, 05:53 PM
n982sx n982sx is offline
Mine are over. From outer surface to inner my layers are elevator skin,counterbalance skin ,spar flange, inboard tip assembly flange. I could not get the spar flange to nest inside the inboard tip assembly flange.
The plans are not clear but it only worked one way for me.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 04-20-2014, 07:02 PM
Thanks! That is how I've got mine. One side looked good one way, the other different! I've straightened all the flanges and have it your way now?. that seems right to me.
Old 09-16-2015, 08:25 PM
smash smash is offline
Thanks for the posts. Here's a picture of how I've assembled the spar overlapping the flange of the tip rib.
Old 11-15-2016, 12:24 PM
HAL Pilot's Avatar
HAL Pilot HAL Pilot is offline
Hey All
Along the subject off these parts, mine don't fit for some reason. Any thoughts. It almost seems like the flange bend on the E 902 spar is not tight enough so the holes sit a bit higher than the 904 flange holes and don't line up. See pics.
Pete
https://www.dropbox.com/s/fidxjabtya...g%202.jpg?dl=0
https://www.dropbox.com/s/rqvdepg0q7...tting.bmp?dl=0
Old 11-15-2016, 04:00 PM
MED MED is offline
Page 9-22, note after step 1: 'E-913 counterbalance skins lie underneath the skins.'
Sorry - answered a different question.
Old 11-15-2016, 06:26 PM
mturnerb mturnerb is online now
I just riveted these today. Look exactly like this. Only way it really fits. The tricky part is skins. But it all worked when I clecoed it together.
Turner Billingsley
RV-14A built/sold N14VB
RV-10 in progress as of May 2020
https://tbrv10.blogspot.com/
https://turnerb14a.blogspot.com/
