I fixed my issue with this the last few weeks. I also didn't want to bend the stick any. I cut the bottom of the sticks where my current bolt hole was, and I slid the stick in .7" from the old location and drilled a new hole. This slid the stick aft, but was still slightly touching some switches. Next I backed out each rod end bearing (3 of them) from the back seat bellcrank and the forward attach location. I lengthened each by 1 turn. This gave me about a half inch clearance at the grips. Make sure you don't have any interference anywhere when it's over. YMMV and if you choose to go this route it will take a little thinking and such to make your situation work.
While doing tall that, I installed my seats, hooked up rudder pedals to the rudder and found that I was comfortable at about the middle range of the seat adjustment, and even if someone needed to scoot the seat all the way forward, I wanted to make sure that a full aft stick would be possible.
Andrew Austin
RV-10
-Flying!
