  #21
Old 11-06-2016, 03:25 PM
Rupester Rupester is offline
I did not install a PB during my build, and have no intention of retrofitting one. Have not needed one in four years of flying. But if I were building all over again, would I install a PB? Yes.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 11-06-2016, 04:33 PM
912ry 912ry is offline
Default parking brake
I installed one during the build. Not hard to do then. I've used once or twice a year for the last three years. I like having it.
Old 11-06-2016, 05:39 PM
I've been flying my -6 for 15 years and have never wished for a parking brake.
BUT, i'd put one on the next airplane, and might eventually retrofit one to the -6. You never know when you'll land solo somewhere windy or unlevel.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-06-2016, 05:48 PM
No parking brake. I do have the modified (two tabs on front) Bogart tow bar, which can double as a parking brake. I just have to remember to stow it within reach if flying solo.
Old 11-07-2016, 02:53 PM
TimO TimO is offline
In over 10 years on my RV-10 I maybe wished for a parking brake 1 time. So I didn't put one on my RV-14. But, while I was doing my flyoff I had one time I could have used it in the RV-14. I allowed a friend to taxi up to the pump first and that left me hanging, facing uphill to the pump. I made do fine.
Ideally I would have turned the plane and it wouldn't have been an issue.
I do see where they are occasionally of value, but I've heard so many stories of them leaking and really don't care for any added work to install, or locating another place for yet another knob. So I don't have one. It's just a personal preference thing. Many will want it, many will not care. I just don't think the ROI on it would be worth my time in my place. I fly lots of X/C and it's rare that I can't get positioned somehow in a wind friendly position to get out of the plane and get to the pumps.
Tim Olson - CFI
RV-10 N104CD - Flying 2/2006 - 1400+ hours http://www.MyRV10.com
RV-14 N14YT - Flying 6/2016 - 350+ hours http://www.MyRV14.com
Old 11-07-2016, 04:45 PM
hawkeyestof's Avatar
hawkeyestof hawkeyestof is offline
Installed parking brake on my 8 during build and have been very happy to have it on several occasions. In Puerto Rico, once in Alaska and in several stateside (small) airports with sloped area at gas pumps. If you fly in/out home field and with pax you're good to go without. But, when you need it you really need it.
Jerry Stofer Georgetown,TX
RV-14 empennage, wings and fuse done.
RV-12 N238GS flying
RV-8A N838GS IO-360 C/S WW prop - SOLD
Flew her to Alaska and Caribbean Islands
Wright Bro Master Pilot Awardee
Double VAF combat exclusion -
double contributions made 2012, ......, 2020
Old 11-20-2016, 12:46 PM
maniago's Avatar
maniago maniago is offline
Default Why not a line lock?
I've been thinking about this, and was wondering why not use a manual line lock, like from Jegs for $40? Wicked cheap compared to a parking brake, and brake fluid compatibility not withstanding (which I'd have to research), I'm thinking a lock on the pilot side wheel only (making super easy installation) ought to be enough to give time to get out and place the chocks on the plane, esp on a taildragger. Its not gonna roll away - maybe in a slight circle till you get out.
I cant think of any down sides to this. Thoughts?
http://www.jegs.com/i/JEGS-Performan...63028/10002/-1
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Old 11-20-2016, 02:33 PM
Ron B. Ron B. is offline
You would need two!
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 11-20-2016, 03:09 PM
maniago's Avatar
Originally Posted by Ron B. View Post
You would need two!
Uh, no. Re-read my post. Thats what I'm getting at.
Mani
N251Y (res)
Old 07-23-2019, 03:42 AM
KayS KayS is offline
would like to dig out this old thread. I didn't install a parking brake in my almost completed RV7 and think now it would be good to have one. But I hesitate the effort to retrofit the standard parking brake system.
Mani suggested to use a manual line lock (link from Jegs still works). Anybody tried that?
Kay
