  #11
Old 11-04-2016, 10:07 PM
simatos simatos is offline
Thanks for the AS link, I hope the one pound can will be enuf!!!!!
Old 12-29-2016, 03:29 PM
rapid_ascent rapid_ascent is offline
OK I ordered the Fuel Lube equivalent from ACS. I also managed to remove my 90 degree fittings so I could rotate them to point down. When I removed the fitting I could see that there is already some lubricant on the o-ring and flange. I'm assuming this is the Fuel Lube stuff. How much do you normally apply? I'm wondering if it is good to go or if I need to wait until my Fuel Lube arrives before buttoning the valve up?
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
