Originally Posted by Chkaharyer99
Bill,
What about the configuration for a Titan IO-360 with high compression pistons (9.1:1)? Is there a safe setting that can be achieved?
Typically, you want to move the spark closer to TDC when you go with high compression pistons. I would check with with your engine builder to see what their recommended timing is and then customize your P-mags' configuration to match. (Check your data plate, the recommended timing might be on there.)
You can configure the P-mags with either the EICAD program, which you can download from the Emag website or with an EIC. You do not need the EIC to configure your P-mags, but it does make it easier and you can monitor your P-mags with the EIC, which you cannot do with the EICAD program.
Let me know, if you have any other questions.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
