11-01-2016, 12:20 PM
Super Moderator
Check those AFT Spar bolts
It seems that about 40%-50% of the RVs on which I perform CI's or prebuys have the wrong bolt/nut combination on the aft spar. The aft spar actually has some movement on it during flight loads, and can move. Therefore it requires a drilled bolt, castellated nut, and cotter key. Most of the ones I see have a fiber locking nut on them. Some even have the fiber nut on the drilled bolt!
I'd post a picture but I think it is pretty self-explanatory. Most of the RV's can be checked with a flashlight by crawling underneath and looking past the flap. It is also very easy to remove the last two screws on the wing root fairing and peel it back to inspect.
Vic
 Vic Syracuse
www.Baselegaviation.com
11-01-2016, 12:38 PM
Just to clarify, you're talking about the bolt connecting the spar to the fuselage "fork"?
11-01-2016, 02:32 PM
Super Moderator
Yes.
Vic
 Vic Syracuse
11-01-2016, 03:09 PM
and if they are not drilled perfectly square put a set of spherical washers on them.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
11-01-2016, 06:09 PM
Nuts
Mine has fiber nuts with torque seal no movement.Will watch.
Bob
11-01-2016, 07:14 PM
Plans
Vic
My 7a plans clearly show bolt, washer, nut and cotter pin.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
11-01-2016, 08:00 PM
I think the plans have always had it, but my guess is that a lot of people get to that point in the build, and have gained enough confidence that they stop consulting the plans for a lot of things...I know I caught a few mistakes of my own after going back and looking at the plans that I had earlier just skimmed over.
Chris
Chris Johnson
11-01-2016, 09:21 PM
This may sound like OCD, or maybe it's just a side effect of the rigorous engineering we do at work, but...
Prior to the DAR inspection, I photocopied all of the preview plans, and then went over them and verified that each and every item on every page, including each of the detailed drawing, hardware callouts, etc., had been done IAW the plans (or there was a very good reason for a variance), checking off on paper every item.
If I missed anything, it wasn't for lack of trying to verify every item!
11-02-2016, 06:06 AM
Super Moderator
Bob
Why wouldn't you replace it with the correct combination? Takes about 10 minutes per side.
Vic
 Vic Syracuse
11-02-2016, 06:35 AM
Thanks for the Tip...or Heads Up VIC!
It was a pleasure to meet you in LKU for the RV-7 pre-buy!
I learned things from your visit!
Look forward to seeing you at a fly-in.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
