Old 10-30-2016, 05:04 PM
BigD'sRV14 BigD'sRV14 is offline
Default Downdraft paint booth
Hello all. I am looking for information I saw regarding building a small downdraft paint booth with chicken wire on top. It used HVAC filters avaliable at a hardware store. thanks
Dennis Schade
Reno,NV
urischade@aol.com
RV-14 #140298
Completing an RV is not a race, but it is the ultimate victory.
2018 Donation Sent
Old 10-30-2016, 05:59 PM
wirejock's Avatar
wirejock wirejock is offline
Default Booth
I built one from hobby board with a child gate as the spray table. Works great. Easy to modify and build from 1/4" ply almost any dimension. Blower is a Rule 240 bildge blower plumbed to a wall dryer vent. It's documented in my blog. Fuse page.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 10-30-2016, 06:07 PM
An old aluminum window screen works great as a spray surface, too, and small parts won't fall through.
Old 10-30-2016, 07:06 PM
leok leok is offline
This is the downdraft table I built. It has worked well for me.
It is a 2x4 frame wrapped with a blue tarp. The top is plastic mesh fencing. The ends have 20 inch box fans with furnace fans duct taped over them. It has the advantage of being easy to take down and store when not in use.
Building started Oct 5th 2014, Flying since 1/16/2020
http://www.mykitlog.com/leok
RV Hotel, come by and visit if you're in town
Dues paid 2020
Old 10-30-2016, 07:46 PM
PilotFuse PilotFuse is offline
Total newbie here. Why are the fans necessary? Ventilation?
Mike Lemovitz
RV-??
VAF Dues Paid October 2016
Blog and Build Log: PilotFuse.Com
Old 10-30-2016, 07:50 PM
DaleB's Avatar
DaleB DaleB is offline
I used a shortened fuselage shipping crate. Wire mesh on top, a furnace filter and 20" box fan screwed to the bottom. I used the cut out piece from the fan opening spaces off the floor of the box with short pieces of 2x4 to keep some of the spray out of the filter. It worked pretty well.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 10-30-2016, 07:58 PM
wirejock's Avatar
Default Exhaust
They are exhausf fans. I suggest intrinsically safe or squirrel cage. If you use box fans, use them to blow so volitile fumes are not passing through them.
Larry Larson
Estes Park, CO
Disclaimer
Old 10-30-2016, 09:16 PM
PilotjohnS PilotjohnS is offline
Default My plan
My plan is to build a simple 4' x 2'x 2' box out of 1" pvc and 6 mil plastic tarp. I will use a 20 " box fan from walmart and hpa furnace filter. I plan to suck air down when priming then flip the fan around and blow air up thru the grate ( and filter) when drying to keep the bugs off, if needed. This will be for primer only. And i hear primer drys pretty fast. I was going to make the front to back pvc pipes removable so that i can break it down to store.
John S
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Electrical 5% in work
Firewall Forward 5% in work
Old 10-31-2016, 04:53 AM
Quote: They are exhausf fans. I suggest intrinsically safe or squirrel cage. If you use box fans, use them to blow so volitile fumes are not passing through them.
I should have mentioned, I used Stewart Systems water based primer exclusively. No worries on flammability.
Without the fans on, overspray will come back up through the mesh contaminating the shop.
Dues paid 2020
Old 10-31-2016, 05:55 AM
1001001's Avatar
1001001 1001001 is offline
Here is mine:
http://www.brunbergs.net/?p=296
http://www.brunbergs.net/?p=318
It's mostly good for small parts. You probably want a bigger surface like the 2x4 frame shown in another post above.
