05-15-2016, 03:34 PM
Originally Posted by jjconstant
Vetterman actually recommends putting mouse milk on the ball joints every time the cowl is off. I think when that joint can move freely it puts less stress on the exhaust hangers,
rubber cross-ties, and generally less stress on the whole exhaust system.
I agree with Jeremy. I use mouse milk every time the cowl comes off.
Venice, Fl
05-15-2016, 06:15 PM
I sealed my firewall, it is very complicate to access all spots, my back hurts! Let's see if it stops, fact is I was worried about source, but aft a long research I found no evidence of anything wrong.
Some smoke build up and gets its way to cockpit on ground with low speeds and RPM, smoke don't dissipate like in the air when you are fast, I also tightened some bolts on engine and checked my ehxaust.
Guilherme Plassmann (Brazil)
RV7A (Mr Flame) slow kit S/N 74285 Finished 04/14/15😀😀😀😀flying
G3X
Superior IO360
Sterba prop
TSFlightlines hoses
LR30,PRM1,C560,C510S,HS125,B350 FAA/ANAC Pilot
Donation made 2016
10-26-2016, 08:11 AM
what kind of stuff is mouse milk ?
Pit
flying RV9a
a father & son project
10-26-2016, 09:45 AM
Light oil. Like sewing machine oil.
Dale
Omaha, NE
Previous RV-7 project (sold)
10-26-2016, 11:56 AM
ACS has it
http://www.aircraftspruce.com/catalo...?clickkey=6406
Joe Schneider
RV-7, IO-360, BA Hartzell, N847CR
Flying since 2008
10-26-2016, 02:11 PM
Veering a bit off topic. Mouse Milk is a penetrating oil. 50% or more of it is Toluene, a solvent. We are not really lubricating the joint. A petroleum based lubricant, another 30 or 40% of the make up of Mouse Milk, will just burn off.
What we are doing is breaking down the carbon build up from the oil laced exhaust that will creep in and freeze up that joint.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
10-26-2016, 03:12 PM
Preventing seized joints
Since we are off topic; after buying my 6A I discovered the exhaust ball joints seized. When the exhaust came off to attend to an oil leak I went to work on the ball joints with a wire brush. It was a slow process of working the contamination out of the joint where the brush wont reach, but with about an hour of effort the joints were free and smooth. I now apply mouse milk to the exhaust joints every time the cowl is off.
10-27-2016, 12:40 AM
How is the Mouse milk applied? Do you squirt it onto the out side of the ball joint?
RV7 ZK-DVS
Whangarei
New Zealand
EMS S76 Pilot
10-27-2016, 01:29 AM
That's how I do it. The penetrating properties help.
10-28-2016, 02:09 AM
Cabin smoke
Thanks for mouse milk
What about CO? Is anyone using a CO Detector? I am thinking to install this one:
http://www.aircraftspruce.com/catalo...ickkey=2026276
Any better advice?
Pit
flying RV9a
