  #11
Old 10-26-2016, 10:30 PM
jdmunzell jdmunzell is offline
Default don't be impatient!
I should know better by now, but I was simply trying to rush finishing this little task, as my mind was thinking about the rest of my day's agenda... I should know better...
That's when the "stupid" stuff happens! Ugh...
Jeff
-8 wings, finishing up
-8 QB Fuse just arrived!!!
Old 10-27-2016, 04:24 AM
KRviator's Avatar
KRviator KRviator is offline
I did the same on one of my elevators. Smoothed it best I could and it's still there after about 50 hours.
Just like the bump in the skin behind the baggage compartment, the stop-drilled crack in the canopy after I flexed it a little too much and the second row of holes in the empennage fairing - each a little reminder that I built the plane in my back shed, it isn't perfect but it is mine...
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 10-27-2016, 11:09 AM
".....Just like the bump in the skin behind the baggage compartment, the stop-drilled crack in the canopy after I flexed it a little too much and the second row of holes in the empennage fairing - each a little reminder that I built the plane in my back shed, it isn't perfect but it is mine..."
Good point! Thanks!
Jeff
Old 10-27-2016, 09:15 PM
GregGreen GregGreen is offline
Been there, seen it, and done it. The OCD in me will not allow me to move on. The new skin and stiffeners are not that expensive. I have to always remind myself to SLOW DOWN and double check what I'm riveting. It's a lot less expensive and more productive, but still hard to always do.
Old 10-27-2016, 11:18 PM
81270 81270 is offline
Default Bondo?
I don't know if I've missed something but if you are painting the surface what's wrong with a thin screed of Bondo? I have had to do this a few times to cover "smileys".
Peter Vernon
Eagle Heights, Queensland, Australia
RV8, QB Wings, Standard Build Fuse (85% @ April 12)
email: pve95448@bigpond.net.au
Paid dues ... pleased to support DR
Old 10-28-2016, 02:54 PM
KRviator's Avatar
Because it has been back-rivetted, the lump is proud of the surrounding skin, not below it, so it isn't easily covered with anything.
Old 10-30-2016, 12:06 PM
"...Because it has been back-rivetted, the lump is proud of the surrounding skin, not below it, so it isn't easily covered with anything...."
Exactly! I walked back into the shop after a day or two of ignoring it after I had tried to "fix" it best I could. There it was, still looking like Mt. McKinley with the overhead lights casting its gleam down upon the shiny aluminum..
Went back upstairs and ordered a new skin plus some new stiffeners for the aileron. I figured at this point of the aileron build, I'm not out much! So OCD took over...
I'm sure there will be other goofs at a point where its best to just move on and hide it best I can, but this one was minimal mistake!
Jeff
