Old 10-11-2016, 01:58 PM
N661DJ N661DJ is offline
Default P mag plugs?
I have an IO-390 that is equipped with dual P Mags.
The engine requires long reach plugs with the long reach brass adapters.
P mag documentation suggest the NGK BR8ES plug, this plug when installed in the brass adapter is too short the electrode is 1/4" inside the adapter.
What plugs are used in this configuration?
Talked with P Mag and they said to use the DENSO IKH27 plug, tried numerous auto parts stores, no one stock that plug.
Question, Is the DENSO the only plug that will work?
Dick
Old 10-11-2016, 02:08 PM
Raymo's Avatar
Raymo Raymo is offline
Amazon has them at this link.
https://www.amazon.com/Denso-IKH27-I.../dp/B000M6URAA
Ray
Old 10-11-2016, 04:35 PM
APACHE 56 APACHE 56 is offline
Default Alternative to DENSO
NGK LZFR5C-11 Spark Plug #NGK-92174 (long reach)
Cheaper, more accessible than Denso and I've had much better luck with them in my 390.
Don Stiver
RV8 "Little Pill" N6371S, Merritt Island, Fl.
BPE IO-390, Dual P-mag, MT 3-blade, AFP system
Steen Skybolt: Sold
Old 10-11-2016, 06:52 PM
Good info,
Thanks Don,
Dick
Old 10-12-2016, 06:37 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Apache56 Question ?
I am using BR8ES because so many folks have endorsed them. I had not noticed the the tip length deficit in the adaptor ( my bad ) I am approaching annual and plan replace plugs as suggested by others citing "cheap preventative maintenance and resistors do deteriorate". So, what is the expected benefit of the longer reach plug ?
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 10-12-2016, 06:27 PM
Hi Larry,
as for the benefit, I don't have a clue and that's the truth. I guess a call to Alan Barrett would be your best bet. As an aside I would venture a guess that it has to do with a more efficient ignition process. A guy at Auto Zone mentioned that more autos are going to long plugs in response to my surprise that there were a number of long reach plugs in stock.
Don
Don Stiver
Steen Skybolt: Sold
Old 10-12-2016, 07:19 PM
868RM 868RM is offline
Default plugs
I may be incorrect but what is considered a "long reach" NGK plug is 3/4 inch. The IO-390 plugs adapters need a plug with a 1 inch reach. I'm glad those 5 heat range plugs are working well, but that seems a little hot. I found some 6 heat range NGK's but I'm using the Denso's because of the heat range. They are 9 heat range.
Old 10-15-2016, 10:58 AM
Default pic of NGK and DENSO
Originally Posted by 868RM View Post
I may be incorrect but what is considered a "long reach" NGK plug is 3/4 inch. The IO-390 plugs adapters need a plug with a 1 inch reach. .
Here is a side by side of NGK and DENSO. The DENSO barrel is about one thread longer but the NGK is overall longer. An IA told me the long reach is a heat sink. One more opinion.
Don Stiver
Steen Skybolt: Sold
Old 10-18-2016, 01:55 PM
nucleus nucleus is offline
Lightbulb Laser Iridiums
The latest upgrade to the NGK Iridiums are the "Laser" Iridiums, the difference is that they plate the ground electrode with Platinum instead of Nickel.
Amazing spark plugs.
Dr. Hans Conser
Bozeman Chiropractor
RV-6A 195 Hours, up for sale soon?
Old 10-18-2016, 06:18 PM
gear1 gear1 is offline
Default P-mag sparkplugs
I replaced the extended nose Tempest plugs with auto plugs when I installed the P-mag; at first I used the standard NGK plug used by everyone else, but then I discovered an extended nose plug used in air cooled Porsche engines, the BPR8EIX Iridium. They seem to perform better (smoother) in LOP operation. Same heat range as the non extended. The heat range seems right even with 9:1 pistons, as the plug insulator is a light tan color even when running WOT.
They are available from a number of Amazon outlets.
Craig Taylor
RV8 flying
2020 VAF dues paid with thanks
Navy A7E Vietnam era
Ret. Corporate Pilot: G1159, IA Jet, Jetstar, Falcon 10, 20, 50
