Old 10-11-2016, 01:59 PM
Bones McCoy Bones McCoy is offline
Default RV-8 Weight n Balance question
I am finishing my 8, my weight is 1084lbs. I have a 200hp with CS prop. My W&B puts my Datum at 73.67. That makes me pretty nose heavy. I ran the numbers solo and my W&B stays so far fwd that it looks really ugly once I burn the fuel out. I ran numbers with 45lbs in aft cargo floor, the numbers look better but....
My tail weighed in at 29lbs. Any thoughts on weight mods to the tail?
Bones
Old 10-11-2016, 02:34 PM
Robert Anglin Robert Anglin is offline
Default common problem with the angle valved set up.
Yep this is seen a lot with the angle valved engine and heavy prop set up.
The first thing is that the battery or batteries need to go in the back. You can ballast by putting some lead in the tail. I would only add as much as it take to get you 3/4 to an inch and a 1/4 behind the forward most CG though as you want to keep the weight down as much as you can. Always remember the most aft CG moves forward and you gross weight goes down if you want to do aerobatics later on. Other than that try to sift as much of your weight aft of the fuel tank moment that you can. I am glad you are seeing this as it is something that has gotten a few in bad situations before. If you can get the CG as close to the front of the box as you can with the 8 you are doing the right thing as other than the front baggage most every thing you will load for a trip makes the CG move back not forward. Hope this help. Yours, R.E.A. III #80888
Old 10-11-2016, 03:05 PM
g zero g zero is offline
Default W&b
I have the same set up and a prop spacer ( James Cowl )
My battery is behind the panel , 4.5 gallon smoke tank (and ballast ) where the plans call for the battery and made a new tail wheel that weighs 16 oz more than stock . Mines 1094 with 42 on the tail .
29 sounds pretty light , have you verified the weights ?
I can email you pics of the tailwheel .
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
Old 10-11-2016, 03:24 PM
Carl Froehlich's Avatar
If you do not have your battery mounted aft of the baggage compartment, move it there. If it is already mounted there, add a second battery in the same spot. If you are going to add weight you may as well get some benefit from it. A second battery, even if you don't optimize the power distribution design, will add electrical reserve.
Carl
Old 10-11-2016, 03:43 PM
Default W&B
I wouldn't move the battery , especially considering the weight is almost nothing now days , consider adding weight under the vertical fin on the rear deck and making a heavy tail.
Rv8
N 666 TA
2017 donation paid
Old 10-11-2016, 03:47 PM
SHIPCHIEF SHIPCHIEF is offline
Also try to remove some weight from the front.
Install a lighter starter and alternator, that's as close to the front as you can get (except the prop) Get a light weight flywheel (Ouch $!)
Install a light weight sump, like a Superior or Sky Dynamics.
When you move the battery to the back, you get unwanted additional weight, like more than 3 pounds of battery cable!
I went the opposite direction when I removed my powerful but weighty Mazda Turbo Rotary and installed a Parallel valve conical mount IO-360 with Catto prop and light starter & sump.
I move the battery forward. The removed cable alone was 3.2 pounds!
My son Peter had a rear mount alternator on his Pitts, so he machined the alternator pulley off the flywheel to save weight. He also switched to an AeroVoltz LiFPo4 battery. It all counts!
G Zero has a good point, add a little weight very far aft.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 10-11-2016, 04:25 PM
ronschreck's Avatar
ronschreck ronschreck is offline
OK, I really don't know what you mean by "weight is almost nothing". But if you are considering adding weight under the vertical fin read this:
http://www.vansairforce.com/communit...d.php?t=133740
Disregard the negative comments. The mod works!
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 10-11-2016, 04:54 PM
[quote=ronschreck;1118035]OK, I really don't know what you mean by "weight is almost nothing".
I meant today's batteries, my Battery Tender brand battery weighs 3 lbs
I like your "ballast tank " , I'll add that to my list of future upgrades.
Rv8
N 666 TA
2017 donation paid
Old 10-11-2016, 05:51 PM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
Is it painted yet? Can make a significant difference as most of the paint is behind the c/g...
If it is, a little weight added to the tail = a whole bunch taken off the nose if it's already equipped as you want it...
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Sept 8, 2019
Old 10-11-2016, 06:00 PM
DanH's Avatar
DanH DanH is offline
If you care, a PC925 on its side fits the stock rear battery tray. And it will blow up a lot of air mattresses.
Dan Horton
RV-8 SS
Barrett IO-390
