Old 10-10-2016, 04:04 PM
bob888 bob888 is offline
Default Fuel lines
Anyone have thoughts re pros/cons on Aeroquip flexible tubing vs stock aluminum tubing for the line from wing to tunnel?
Old 10-10-2016, 04:41 PM
Kyle Boatright Kyle Boatright is online now
Stock Aluminum is easy and inexpensive. IMO, you should make them from the outside in, rather than inside out as the plans call for.
What I mean by that is to make the two 90 degree bends outside the fuselage, add the hardware and flare that end. Then, feed the un-flared end towards the tunnel, get that length right as you fit it, and cut, add hardware, and flare the tube at the tunnel. The plans have you leaving the "outside" ends unfinished until it is time to mount the wings, which makes that a much more difficult operation, IMO.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 10-10-2016, 05:05 PM
aturner's Avatar
aturner aturner is offline
My thought.....that line is easy to make, and aluminum tubing is cheap and lasts forever. Upgrade to 5052 if it floats your boat, but flexible tubing is just money down the drain.
-Andy Turner
RV-10 N784JC
Old 10-10-2016, 09:18 PM
N427EF N427EF is offline
I agree!
I added a couple of 90 degree bulkhead fittings for ease of installation.
One in the lower fuselage portion terminating near the tank pick up source
and the other in the tunnel wall. This will greatly simplify your tubing installation and allow you to complete the fuel lines except for a short piece
from the fuselage to the wing tank pick up fitting.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 10-10-2016, 11:16 PM
Thanks guys. Regarding Kyle's suggestion that the bending should be done first...can the tubing be installed (slide in from outside) with the wings on?
Old 10-11-2016, 05:00 AM
N520TX's Avatar
N520TX N520TX is offline
Yes - there's room to slide it in from the outside with the wings on. I just did this month or so back.
Ron Walker - 40XS
RV7a - Flying
RV10 - Flying !
FFI Flight Lead - www.FalconFlight.aero
Old 10-11-2016, 05:56 AM
Auburntsts's Avatar
+1 -- Compared to making the brake lines, the fuel lines were a piece of cake. And I upgraded to 5052.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 10-11-2016, 06:52 AM
Toobuilder's Avatar
Plenty of discussion on the pro and cons of hose on this forum, but I would caution anyones use of multiple 90 degree fittings on the suction side. Might not be a big deal for most people, but if you intend to operate in very hot weather, high altitude, or with auto fuel, you really increase your risk of vapor lock issues. Every 90 is a restriction and creates a cavitation hazard, so use them sparingly. If you have to use a bulkhead fitting, see if a 45 will work instead.
I'm rebuilding my fuel system for the Rocket right now and since I plan on running auto fuel, I'm trying to eliminate all 90's in the system.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 10-11-2016, 07:17 AM
Lots of discussion on this topic over the years. While we are in the hose business, there are places where rigid tubes are better, and yes, less expensive. We do combinations of both. Its really up to the builder and what her wants for his plane.
Tom
Ridgeland, SC
Old 10-11-2016, 03:45 PM
Default good point
Plenty of discussion on the pro and cons of hose on this forum, but I would caution anyone use of multiple 90 degree fittings on the suction side. Might not be a big deal for most people, but if you intend to operate in very hot weather, high altitude, or with auto fuel, you really increase your risk of vapor lock issues. Every 90 is a restriction and creates a cavitation hazard, so use them sparingly. If you have to use a bulkhead fitting, see if a 45 will work instead.
As you see in my tag line.
My 10 is set up for auto fuel and I do operate in very hot weather and high altitudes and without any issues.
I do agree that 90 degree elbows should be avoided but the 2 elbows in my fuel system along with multiple other 90 degree "corners" to and from the Andair fuel selector have not cause any fuel delivery issues.
Ernst Freitag
