Old 10-03-2016, 08:12 PM
kaber56 kaber56 is offline
Default Antennas and locations
Hi all,
For those of you who are flying, what kind and where did you mount all your antennas? Vans has yet to put out section 52- antenna installations. I know the comm antennas are located on the bottom fuselage but how about all the others- GPS, VOR/GS/LOC, MB, TRANS/ADSB etc.? Help and photos would be greatly appreciated.
Old 10-04-2016, 04:47 AM
Ron B. Ron B. is offline
Transponder holes are under baggage floor , co-pilot side slightly, ADSB holes are way back under the tail. I installed my GPS puck behind the rear window, off to the side of center to clear the underlying structure.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 10-04-2016, 05:54 AM
Thanks Ron,
Is your ADSB antenna a blade or post? Can you send some pics? What brand of antenna are you using?
Old 10-04-2016, 08:53 AM
jswareiv jswareiv is offline
Default Antennas
I did the same as Ron. I used the blades from Delta Pop and the comms from Van's. I originally purchased two other comm antennas, but the holes didn't line up with what Van's had in the bottom skin (They came with 4 holes to attach instead of two). People have said the sticks work just as well as the blades, but I was afraid I might bump it and break it off and I like the look of the blade better. I have the GPS antenna same as Ron on the pilot side off center and two more on the glare shield, one for the G3X and one for my backup GRT Mini. I do have some pics on my website if you want to look at that, but your really just have the two blades or sticks to add and those holes are already there for you. I don't have VOR, just using GPS.
Stoney
First RV-14 Flight 04/17/2016
Serial #140087, N214SW - Sold
Old 10-04-2016, 09:13 AM
Originally Posted by kaber56 View Post
Thanks Ron,
I do not have a ADSB antenna as of yet (Canada) , but plan to next spring for US travel.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 10-04-2016, 04:17 PM
n982sx n982sx is offline
Here's a link to my GPS antenna installation for the GTN 625
http://n626km.com/rv14log017/index36.html
I just used the standard stick antennas for ADSB in and out. The 978mhz ADSB in antenna is a little longer than the 1090 transponder antenna. Stein sells both kinds.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 10-04-2016, 05:35 PM
Carl Froehlich's Avatar
Home brew wingtip VOR/ILS antenna.
MB antenna is a 37" piece of wire connected to a firewall BNC connector and strung under the engine using some standoffs on the engine mount.
Both work well.
Carl
Old 10-06-2016, 05:35 AM
Talking
Thanks guys!
Old 10-06-2016, 10:27 AM
JHartline JHartline is offline
Default Antennas
If you have no other plans today, search "antenna musings" in the forums and you will receive a lengthy reading assignment. And a lot of good input
I'm mulling over all the options as well...just not that far along yet.
James Hartline
Carrollton, GA 5GA2
RV-14 - First flight 4/7/2019. Phase I complete as of 9/11/2019!!
