Old 10-03-2016, 05:05 PM
Simon Hitchen Simon Hitchen is offline
Default Paint the screws or not
Im well into the painting process now and have finished both wings. Question I have is should I paint the screws that hold the fuel tank to the spar? I was thinking single stage urethane but wondered how well the screws hold up to the screwdriver. Id rather have unpainted screws than untidy chipped ones.
Simon Hitchen
Port Perry, ON, Canada
7 Tip Up, Titan XIO-360, Dual P-Mags, Airflow Performance matched Injectors, Sensenich FP Prop, Dynon Skyview, GTR-200, GTX-327
FLYING!
Old 10-03-2016, 05:14 PM
Chino Tom's Avatar
Chino Tom Chino Tom is offline
The screws that were not going to be removed (like the fuel tank screws)
are painted on my RV. All of the ones that will be removed for inspections
are unpainted stainless.
Tom Prokop
Chino, CA
RV-8A,180/CS/Carb, AFS 4500 EFIS/EMS
RV-6, sold, 820 hrs of fun.
Old 10-03-2016, 05:56 PM
f14av8r's Avatar
f14av8r f14av8r is offline
Default Fuel Tank Screws
When I had to remove my fuel tank, I sure was glad none of my fuel tank screws were painted! Not having the screws painted made removing and replacing the tank much easier and avoided damaging the paint job.
Randy King
Tampa (Wimauma), Florida
RV-4 N212CS (sold)
RV-8 N184RK (flying)
Flying an A320 to pay the bills
Exempt and gladly donating anyway - Current through March 2021
Old 10-03-2016, 07:29 PM
I agree, that's why I left them out during the paint job, just incase I have to remove a tank at some point.
Simon Hitchen
FLYING!
Old 10-04-2016, 05:05 AM
jibby212 jibby212 is online now
If you want painted screws I would use stainless. Sand blast them and paint separately.
Old 10-04-2016, 05:39 AM
Captain Avgas Captain Avgas is offline
Using stainless screws for the fuel tanks is very bad engineering and would not be approved by Vans. Milspec #8 stainless screws are typically 80,000 psi Ultimate Tensile Strength. Milspec cad plated steel screws as supplied by Vans are 120,000 psi.
I'd use the cad plated screws supplied by Vans for the fuel tanks and not paint them. People think that they're never going to take off their fuel tanks ...but many have to to fix leaks down the track.
Bob Barrow
RV7A
Old 10-04-2016, 06:33 AM
sblack sblack is offline
Nice paint job btw!
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 10-04-2016, 09:04 AM
dougknight dougknight is offline
I took a single hole punch and made little rounds from blue masking tape and put them over the screw heads prior to painting. 650 hours later it still looks like the day it was painted. In the event of ever having to pull the tank simply score with a paint cutter and peel the tape off.
Old 10-04-2016, 10:17 AM
TCONROY's Avatar
TCONROY TCONROY is offline
I just had my -7 painted and I spent quite a bit of time dividing up all the screws into individual baggies identifying what they were for and what color they should be painted. I'm really happy I did that as the resulting painted screws looks really good. I figured that if they get beat-up over time I can switch to stainless or just have some more painted.
________
Trevor Conroy CFII, MEI
Airbus Pilot
N781TD
RV-7
First Flight - April 12, 2015
Construction Log
Old 10-04-2016, 10:32 AM
wirejock's Avatar
wirejock wirejock is offline
Default Wrap
Not to hijack but what if you wrap? Would it be better to wrap without screws then run them in a small hole or wrap over them and hope they never have to come out?
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
