Old 10-15-2014, 09:08 AM
douglassmt douglassmt is offline
Default GTN 650 Dimmer Settings
This falls under the category of "minutiae" or "obscure but potentially important."
I have a GTN 650 and opted to use its internal dimmer instead of connecting it manually to the panel dimmer - advice from Aerotronics and/or Stein I believe.
However, when I occasionally fly at night (or into the night) the panel won't dim, leaving me with a bright, night-vision-destroying light in the cockpit. I stopped at Aerotronics last week and Jason changed some settings that I am certain will help, but I thought I would plumb the vast reaches of VAF for that lone soul who might have already trod this path.
If you have a GTN 650 that is set up to use the integral dimmer, and you fly at night, have you found settings that cause it to dim properly between bright sun and low light?
I have had the following problems with different dimmer settings I've tried: it wouldn't dim at all when flying from daytime into night; it would dim so far that it went black; if started in the dark for a before dawn departure it wouldn't turn up the light so it was visible in daylight.
Bryan Douglass
=VAF= 2020 dues paid
RV-10 N242BD
Old 10-15-2014, 09:31 AM
rleffler's Avatar
rleffler rleffler is offline
Bryan,
Let me know what you end up with. Now that it is dark before my bedtime, it's time to get night current and start playing with all the dimmer settings. I'm configure like you are.
thanks,
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 10-15-2014, 12:24 PM
RV8iator's Avatar
RV8iator RV8iator is offline
Default GTN Setup
Next time I'm at the airport I'll get mine. There's 2 or 3 different settings that affect the dimming. I have mine adjusted where it works great. It dims a bit slower I would like but it finally settles into a nice display.
I know they are buried in the SETUP menu.
Jerry "Widget" Morris
RV 8, N8JL, 3,000+ hours on my 8.
VAF #818
Saint Simons Island, GA. KSSI
PIF 2008, 2009, 2010, 2011,2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019, 2020
I just wish I could afford to live the way I do
Old 10-21-2014, 03:51 PM
Default Mine
Here are my settings. It still seems to lock on bright when started in the bright light. When started in the dark it seems to dim appropriately. Any help would be appreciated.
Bryan Douglass
RV-10 N242BD
Old 09-19-2016, 06:55 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
Ever get a resolution to this? My GTN is dimming properly when I start up, but as the sunrises, the dim never increases the brightness to accomodate. It's acting like it just reads the light at startup but never looks for a brighter level later on. I am having to powercycle the GTN in flight to get it to properly raise the brightness.
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 09-19-2016, 08:01 PM
Walt's Avatar
Walt Walt is offline
That's why I always install a dimmer pot!
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 09-20-2016, 03:28 AM
Aiki_Aviator's Avatar
Aiki_Aviator Aiki_Aviator is offline
Default Dimmer weird
I have the same issue and I recycle in flight to get appropriate response also.
Regards,
Andrew.
Andrew Long
#41055
RV10: Happy little Vegemite :-)
Feb 2015: Now fully functional..... and quick
http://www.ozrv10.com
Old 09-20-2016, 10:06 AM
I guess it's time to call Garmin and see if this is a bug.
RV-10
N928MT
Build Project Site
Old 06-14-2017, 12:53 PM
jliltd jliltd is offline
Can an external dimmer control attached to the GTN lighting circuit be a PWM type or does it have to be a legacy type rheostat? Or either?
Jim
RV-8
(a few more airplanes too)
Old 06-15-2017, 02:03 AM
Default Resolution??
Does anyone have a solution as yet?
Andrew Long
#41055
