Old 09-16-2016, 06:28 AM
AirbusPilot AirbusPilot is offline
Default changing oil hot or cold???
Hi All,
I have always changed engine oil on my RV-8 after flight so the engine is hot. Yesterday I was talking with an inspector from Chilean FAA and he told me why you do that, is there any lycoming SB, SI or recommendation that said the engine should be hot for changing oil?, so I said yes, then he told me show me a document. I have been searching and I can find any recommendation about it.
Please help
Fernando Abasolo
Santiago Chile
SubSonex waiting for tailkit to arrive
Flying phase II RV-8 (SCSE) Serial Number 83290, Tail Number CC-AJC
Flying RV-8 (SCTB) Phase II 600 hours and counting since February 22nd 2010
Serial Number 82727, Tail Number CC-PXG
Lyc. IO-360, Hartzell Prop
VAF #2056
EAA Member 774981
Old 09-16-2016, 06:47 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
In the summer, I'll just drain the oil without running the engine first. If the outside air temps are warm enough (80? F / 27? C) the oil drains just fine without any addition coaxing.
In the winter, in Minnesota, doing the same thing would result in the oil taking days to drain so during those times I'll fly for an hour or so then drain the oil afterwards while it's still nice and hot.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 09-16-2016, 07:25 AM
Auburntsts's Avatar
I'm not aware or any Lycoming, or FAA document for that matter, that recommends running the engine prior to an oil change to warm up the oil. Lycoming SB 480E, Oil and Filter Change and Cleaning, only states when and what to inspect, not how to do it. Nor does it say to do so in my Lycoming operators or maintenance manual (to be fair I only have the manuals for a 540).
So why do a lot of us do it that way? It boils down to sort of a best practice for 2 reasons:
1. Warm oil drains faster than cold oil
2. More importantly, IMO, running the engine and warming the oil will maximize suspension of contaminates in the oil that we want to remove from the engine
Is it mandatory or actually necessary? In my opinion, nope. But I will continue to do that way. YMMV....
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 09-16-2016, 07:33 AM
Gary 40274 Gary 40274 is offline
Default Better drainage
Some feel that warm oil will drain more completely. However we still have about a quart in the oil cooler that never drains. So at oil change we never get all the old oil out
Gary Specketer
Old 09-16-2016, 07:40 AM
Mel's Avatar
Mel Mel is offline
THIS is the primary reason to drain the oil when it is hot.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-16-2016, 07:49 AM
sblack sblack is offline
yes, it's the only way to get the sludge out. You are leaving a bunch of **** in the engine if you drain it cold. It's kinda like mud and it just collects there in the corners.
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 09-16-2016, 08:14 AM
ChiefPilot's Avatar
I have a filter on the engine that does this for me when the engine is running. Not sure how much difference draining the oil when warm would actually make. Haven't found any significant amount of sludge in ~650 hours either, so who knows?
Old 09-16-2016, 09:19 AM
jpowell13 jpowell13 is offline
I just changed oil yesterday after running the engine first. When I removed the filter, it was full of oil and made a bit of a mess. Does most of that oil drain out of the filter if the engine is not run prior to oil change? John
Old 09-16-2016, 09:21 AM
Auburntsts's Avatar
No. Some, maybe, but there will always still be quite a bit in the filter unless you have an angled oil filter adapter.
PP ASEL-IA
WAR EAGLE!
Old 09-16-2016, 09:25 AM
sglynn's Avatar
sglynn sglynn is offline
Default warm oil
It takes forever for cold oil to drain out. PERIOD.
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
