Go Back   VAF Forums > Model Specific > RV-6/6A
  #11
Old 09-14-2016, 08:24 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Originally Posted by BruceMe View Post
So this plane flipped over and remarkably, the vertical and rudder only got minor damage at the tip. I could in theory salvage/fix the vertical I have.
Instead I opted to replace it. The trouble is that nobody has the non-counter weighted tail anymore. I've looked and looked _AND_ I tried to order parts from Vans to repair the one I have... I got the bigger RV-8 parts. So now I'm at a loss, I can easily get the raw stock and rebuild the tail I have using the plans with the airplane or try to make the bigger RV-8 tail fit.
btw, I too want the smaller tail, cause it works, looks right and fits.
Any advice?
Could still build one from plans? I'm pretty sure the -6 plans have all the dimensions and such that you'd need. You'd need access to a brake I think but beyond that it seems pretty straightforward, if labor intensive.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 09-14-2016, 10:05 AM
BruceMe's Avatar
BruceMe BruceMe is offline
Originally Posted by Raymo View Post
Lots of -7s flying with the larger tail and light weight, FP, prop but most install a weighted prop plate from Saber to help keep CG where they want it and allow sufficient baggage.
I plan to install either the 15 or 20 lb plate, as needed.
Mine has it already with the smaller vertical
Bruce Meacham
Building RV-4A 18ZM
Built/Own RV-4 254MM
First RV RV-3 3456B
VAF annual donation on autopay
Old 09-14-2016, 10:10 AM
BruceMe's Avatar
I can make a brake in 20 minutes with a 2x4 and few spare door hinges. That's easy. I think I'll head to airparts and get some aluminum.
Also the shop I'm using has a nice 4' bender/brake for the spar.
Bruce Meacham
Building RV-4A 18ZM
First RV RV-3 3456B
Old 09-14-2016, 10:43 AM
Van's still sells all the parts for the -6 tail, they just don't advertise a tail kit. You can still find the parts on the list.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 09-14-2016, 11:19 AM
BruceMe's Avatar
It's the newer style, not the older non-counter ballanced. I tried.
Bruce Meacham
Building RV-4A 18ZM
First RV RV-3 3456B
Old 09-14-2016, 12:10 PM
RViter RViter is offline
Default I have original -6A VS only ...
...(snipped) The trouble is that nobody has the non-counter weighted tail anymore. I've looked and looked _AND_ I tried to order parts from Vans to repair the one I have... I got the bigger RV-8 parts. So now I'm at a loss, I can easily get the raw stock and rebuild the tail I have using the plans with the airplane or try to make the bigger RV-8 tail fit.
I replaced the 'classic tail' (i.e. "small") with the -8 VS/Rudder set because the rudder was not included in the project kit (RV-6A QB). Building the original rudder required a bunch of line items, and the -8 VS/Rudder set was a single line item. Convenience order ...
Part of the aft weight penalty is the counter balance lead wt, think it's 20 oz. Another factor is the 0.020 skin on the rudder, and also the size increase.
With the O-360 and FP Sensenich prop the tail wt is a consideration but baggage wt is not the main concern - the Vans recommended gross with two occupants is 1650 lbs and so a couple of "me" (235) and some fuel is already there. [Yes, I've seen POH's with 1800 and even 2000 lbs gross limits.]
Yes, I still have the classic VS in the attic ... and it's QB (factory built). If anyone is interested. You'll still need a 'classic, non-counter balanced rudder'.
gary
RV-6A QB Tip-Up, 1st Flight 3/18/17
O-360-J2A (modified & F/I), Sensenich FP (cruise)
VP-X Sport, Dynon SkyView, VFR day
(FFZ) Mesa, AZ - N234GB -
www.mykitlog.com/garyc
Old 09-14-2016, 01:09 PM
rvbuilder2002's Avatar
I agree that with two 235 lb'ers in the seats the impact of the heavier tail doesn't matter.
With a couple of 170 lb'ers in the seats the impact on baggage capability is the major concern.
Scott McDaniels
Hubbard, Oregon
Old 09-14-2016, 01:20 PM
Default Should have written more ...
With my two 235 pounders there is no weight in the baggage area, worth mentioning. It's all occupants and fuel, to the max gross wt. Scott - will PM you a couple of W&B questions especially on Loading/Unloading & Planing/De-Planing sequences. Or new thread.
thanks
gary
Old 09-14-2016, 03:57 PM
GLPalinkas's Avatar
I think I would take advantage of this offer if I was looking to rebuild the older tail.
I built my -6 with the -8 tail and never looked back. Flies great and is pretty fast for a O-360 with a fixed pitch Sensenich.
Just my opinion.
Venice, Fl
Old 09-14-2016, 05:00 PM
AJ85WA's Avatar
AJ85WA AJ85WA is offline
Default 6 with 7 tail
I built my 6 with the 7 tail, because that is what was available to me at the time ( Time is money & worth more)
AJ Wessels (Perth Australia)
Completed - RV6
http://rv6aj.wordpress.com/
