Go Back   VAF Forums > Model Specific > RV-6/6A
  #11
Old 09-10-2016, 07:23 PM
NYTOM NYTOM is offline
Originally Posted by rockwoodrv9 View Post
Does this mod allow the seat back brace to be removed or once it is installed, it is done?
Check out the AntiSplat site, there is a video of the installation and exactly what it is.
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360. Phase 1
Old 09-10-2016, 07:40 PM
brooksrv6 brooksrv6 is offline
After installing the amost a 14 kit you can add a 4th row of hinge halves to the seat pan for the bottom of the seat back.
Old 09-10-2016, 09:24 PM
blaplante blaplante is offline
Default big/tall RV6 mods
Also you can put a spacer in under the main hoop of slider. I did 1/4", but I imagine you could go bigger. That increases the headroom a bit. Obviously you have to do that as you are initially building the canopy, not later.
RV6A in phase 2 as of April 2016
Donation made Sept 2019
Old 09-10-2016, 09:41 PM
PCHunt PCHunt is offline
I installed the Almost-a-14 mod in my -6, and couldn't be happier! It is literally amazing how much more comfortable the seating and headroom are, for such a relatively minor change.
I now have to sit on an extra cushion to see out properly. The mod "lays" the seat-back down and backward, and it seems to make all the difference.
Also, if your passenger/co-pilot is on the small side, they can keep their seat-back tilted forward, which makes the shoulder-room better.
Wouldn't do without it!!
(6'2, 240 lbs, but short legs and tall torso)
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 09-11-2016, 06:18 AM
Bighorn Bighorn is offline
Thanks again everyone for all the good tips. I spent alot of time reading about all the different models but was just about to give up on the RV.
I glad I finally got enough gumption up to ask a few questions, thanks for being patient with a newbie
Old 09-11-2016, 06:21 AM
Jesse's Avatar
Jesse Jesse is offline
I've done this in a -9A and it worked great. I'm hoping to add this mod to my -6A soon too.
Jesse Saint
Old 09-11-2016, 06:43 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default long legs
Remember the air vent can be a knee knocker and limit movement on long cross countries. Mine is located under the panel obviously within reach and between my legs on a hinged panel. Works great.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 09-11-2016, 02:46 PM
gereed75 gereed75 is offline
6'4"+, 215. I have a slider 6 with my own version of the "almost a 14" mod. Moved the last seat bottom hinge back about two inches. No extension on bottom of panel. No side panels. Also have rudder pedals pretty far forward.
I have also notched out the "flange" on the top of the fuse sides at the shoulder. My cabin is now actually 1/2" wider than a 7 at the shoulder.
Pretty comfy. I find that the ability to slide my feet under and to the right of the pedals (no center console) allows me to get a little more stretch and move around a bit on long legs.
The seat back mod and having thin seat cushions makes a world of difference. All the little stuff adds up to make a big difference.
Gary Reed
RV-6 IO-360
WW 200 RV now an Al Hartzell for improved CG
Old 09-11-2016, 07:07 PM
myrv6180 myrv6180 is offline
Default Almost 14
I took out the center brace from the panel to the floor and added a brace from back of panel to subpanel to firewall and now have room for my knees. I am 6'4'' tall and weigh 235. I have flown it 21 years like this and love it.
Old 09-12-2016, 09:08 AM
I'm 6'4" about 265. My RV-6A isn't flying yet, but I have spent plenty of time in the seats making airplane noises. The Almost 14 mod made a world of difference for me, plus the pedals are pushed well forward for my long legs.
I don't know where in Texas you are, but you are welcome to come sit in the plane and make some airplane noises for yourself. I am located in Plano. Just shoot me an e-mail or PM.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
