Old 09-08-2016, 12:14 PM
simatos simatos is offline
Default MODE S for Candada
INteresting wrinkle for Canada--Im buying an ELT from Vans and they are asking for the MODE S code for canada. My local avionics guys say 316 is the code but ther is something called the 15 digit Hexidecimal ID. IS that something that would be on the transponder?? A little confused, ideas would be appreciated, cheers G
Old 09-08-2016, 12:47 PM
TroyBranch's Avatar
TroyBranch TroyBranch is offline
It is on the paperwork when you reserve your registration marks.
Troy Branch
RV10 Built and Flying Since Feb 2009
950hrs Plus
CC EX-2 Flying
SuperSTOL Built and Sold
RV9 Built and Sold
Avid Aerobat Built and Sold
Dues paid Nov 2019
Old 09-08-2016, 01:03 PM
flyboy1963's Avatar
Default amrchair advice
the mode S code is something like; C011DF like for your C170
in the aircraft reg papers as noted by Troy.
the 15 digit hex code is ON the ELT, and you will use it when you register it.
the Mode S code for Canada is 316, but that's not specific to your aircraft, it's just a 'country' code.
(please verify the above as fact, not internet opinion!)
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 09-08-2016, 05:21 PM
Consider the fact partially verified, Perry. It's a 24 bit code rather than the 15 bits you had referenced. Other than that little detail, all's good!
The Mode S code is the "digital fingerprint" assigned to your aircraft. It used to be that Mode S transponder equipment was the only stuff we had that used this ICAO-standardized code, hence the reference to it being a Mode S code. The reality is that it truly is a unique digital identifier for your aircraft. It is part of the info that is programmed into your ELT, along with the country code of registry.
I can also confirm that if you have reserved a registration mark, the code is included in the letter you receive from Transport Canada. This letter starts out in bold type with the words:
"RE: Confirmation of Registration Marks Reservation - C-XXXX
24 bit Address / Addresse 24-bits - Bin:" followed by the 24 bit binary code, the Hex code and the Octal code, all of which are different mathematical expressions of the same identifier that makes your aircraft unique.
Last edited by Canadian_JOY : 09-08-2016 at 05:22 PM. Reason: Can't type worth a hoot!
Old 09-08-2016, 07:26 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
The 15 digit Hex ID needs to be programmed into the ELT by the supplier.
Part of the code will be unique to the country where it is registered, hence they need to know that.
They will then be able to programme a unique ID for your unit which will enable it to be registered with your national registry.
The 24 bit code that is mentioned is for transponder mode S identification. You do not need that to be coded into the ELT
The list of country codes is here
Old 09-08-2016, 07:34 PM
Great you guys, thanks so much, just put the request for my Registration so the info should come back with that, Cheers Gary
PS snow yet in Alberta?????
going to ED tomorrow
Old 09-08-2016, 09:15 PM
RV-4 RV-4 is offline
Question ELT
Gary
Would you have a link to the web site where we can get our registration??
That is something I plan on doing in the spring.
Bruno
Old 09-08-2016, 10:05 PM
Flying Canuck Flying Canuck is offline
I reserved my registration number a couple of weeks ago using the Transport Canada General Aviation Online Services site at https://www.tc.gc.ca/eng/civilaviati...-menu-1798.htm. It was issued immediately and I got my hex/binary code right then. Couldn't have been easier.
Claude Pitre
RV-9A #91081, C-GCPT
Dynon SkyView HDX, IO-320 and WW 200RV C/S. Flying as of August 6, 2018
Interactive map of all of my flights here
Old 09-09-2016, 06:28 AM
Just to clarify, in Canada you DO NEED the 24 bit ICAO code programmed into the 406MHz ELT. The US uses a binary code which is derived from the N-number. In this regard Canadian and US requirements are considerably different. In this case the person asking the question is doing so from the Canadian perspective. From this perspective the 24-bit ICAO (or Mode S - they are one and the same) code IS required to be programmed into the ELT.
Old 09-09-2016, 07:07 AM
sbal0906's Avatar
sbal0906 sbal0906 is offline
Just to add to that. The 24-bit code is entered by the installer (or airplane builder in this case) and not Van's. See 10.4 here (https://www.tc.gc.ca/eng/civilaviati...-497.htm#s10-0)
Shamit Bal
http://www.flyaroundthesun.com
RV-9A
Started on wings.
Winnipeg, Manitoba, Canada
