Old 09-07-2016, 08:16 PM
flyingriki's Avatar
flyingriki flyingriki is offline
Default EGT Probes
Just a note. My Dynon probe clamps have shed two ends in 75 hours. One was laying in the bottom cowl, the other vanished....Wonder why they're breaking off?
Tempted to cut the other two off, and probably will.
Old 09-08-2016, 06:57 AM
Robert Anglin Robert Anglin is offline
Default Safety wire.
If these are the band screw type, you can safety them by placing a peace of .021 or .032 wire under the clamp, tighten the screw, then run the wire through the screw driver slot to keep it from turning from vibrations.
Hope this helps. Yours, R.E.A. III #80888
Old 09-08-2016, 07:17 AM
flyingriki's Avatar
All my clamps are safetied. These are the excess ends of the bands.
Old 09-08-2016, 10:55 AM
Mich48041 Mich48041 is offline
Vibration could be the cause. Has the prop been dynamically balanced?
Joe Gores
RV-12 Flying
Old 09-08-2016, 10:09 PM
keijidosha keijidosha is offline
Default Dynamic Balance
I just had this done due to vibration issues. Miraculously smoother. And if you don?t have a vibration issue, you will know that too. Not sure where you are in CA. I used JF Dynamics. Completely satisfied. http://www.jfdynamics.com/
Matt
Simi Valley, CA
RV-4 O-320 F/P
