Old 09-07-2016, 05:29 PM
Jgibson Jgibson is offline
Default Battery Fire Today
Buddy of mine was breaking in his Rotax 503 in his Hawk lite sport plane on the ground today. He had left the master switch on, so the brand new lithium ion battery was low.
We jumped the starter to get it running and observed the volt meter, which sat at 10 volts.
After running approximately 40 minutes of the hour required, the volt meter went to 11 volts, then immediately to 12. At that point, it lit off. As I ran for the fire extinguisher, he fought with disconnecting it and upon getting it free, threw it away from the plane.
It burned and smoked profusely for 5 minutes or so before finally burning itself out. IF this had happened while in the air, there is no way he would have gotten it on the ground before the fire had done serious damage to the plane, IF he could have seen anything through the dense white smoke.
Taught both of us a valuable lesson. I myself will NEVER install one of these until or unless better overcharge protection is in place and unless a low-charge shutoff is in place to prevent it from discharging too far in the first place.
It's just not worth what I saw today, no matter how light and compact it may be.
Old 09-07-2016, 05:33 PM
gasman gasman is offline
What brand was this battery?
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 09-07-2016, 05:49 PM
Yes, please specify brand, model number, and if it is indeed a lithium *ion* battery. If it is, "there's your problem."
I haven't heard of anyone who recommends using a lithium ion battery in an a/c.
Do be aware that there are multiple battery chemistries that include 'lithium' in the name/chemistry. Some are much safer than others.
Charlie
Old 09-07-2016, 06:04 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Charlie
My favorite is dilithium crystals
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-07-2016, 07:04 PM
n82rb's Avatar
n82rb n82rb is offline
are you kidding? 30 years and 7 movies an those things still keep phasing!...
bob burns
RV-4 N82RB
Old 09-07-2016, 07:59 PM
Mike S's Avatar
Senior Curmudgeon
bob burns
RV-4 N82RB
http://www.gmanetwork.com/news/story...ths-to-6-weeks
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 09-07-2016, 08:04 PM
ColoRv's Avatar
ColoRv ColoRv is offline
Brand please...
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
Old 09-07-2016, 08:06 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Default ION or IRON?
As the previous repliers said, we need to know the type of lithium battery. Many of us fly EarthX batteries, which are Lithium IRON (not lithium ion). Flying a lithium ion battery is, well, in a word ... risky, no thanks to their trend for high combustibility. We're not seeing this issue with lithium IRON batteries.
I'm really glad he got the battery out of there, and that it happened on the ground.
So, you have our attention: Was it a lithium IRON or lithium ION battery?
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2020 -=VAF=- Contributor
Old 09-07-2016, 08:25 PM
Tbone's Avatar
Tbone Tbone is offline
Default Thread search?
It seems very similar to a previous thread a while back. Search "A very lucky pilot"... Not sure how to link it..
[...Here you go...try this link It's in the Safety Forum, which is probably where this thread should be...dch...one of the moderators.]
___________
Terry
RV7
XP IO360
Last edited by rv7boy : 09-08-2016 at 09:18 AM. Reason: Added link to other battery thread
Old 09-07-2016, 08:53 PM
Lenny Iszak's Avatar
Lenny Iszak Lenny Iszak is offline
I have a swollen Odyssey PC545 on my bench from a friend's Hawk. It got overcharged due to a bad regulator on the Rotax.
You can't expect any battery chemistry to stand up to overvoltage conditions. It's easily preventable though.
Lenny
