Old 09-04-2016, 10:58 AM
Brettc Brettc is offline
Default Degree countersink #10 screws
Having trouble finding this answer.. Which countersink do I need for the #10 screws on the rudder? Is it 82 degrees, or a 100 degree rivet countersink? On that note, what would the 130/120 countersink so be needed for?
PP ASEL/A&P
Old 09-04-2016, 11:29 AM
Lars Lars is offline
The #10 screws have 100 degree heads, the countersunk pulled rivets used on our RVs typically have 120 degree countersunk heads, though in the latter case I believe Vans mentions just using a 100 degree dimple or cutter for them, in the build instructions.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
Old 09-04-2016, 11:55 AM
Thanks!!! Placing an order then.
PP ASEL/A&P
Old 09-04-2016, 11:59 AM
jimgreen jimgreen is offline
AN426 rivets have a 100 degree head.
From our bible:
"e. Countersunk head rivets MS20426
(supersedes AN426 100-degree) are used on the exterior surfaces of aircraft to provide a smooth aerodynamic surface, and in other ap- plications where a smooth finish is desired. The 100-degree countersunk head has been adopted as the standard in the United States."
You might be thinking of pulled rivets.
Jim Green
RV7 tip up
IO360 Whirlwind 200RV
Old 09-04-2016, 12:10 PM
bcondrey bcondrey is offline
The only "oddball" countersink on the Van's aircraft is for the CS4-4 pulled, countersunk rivets. Those are 120 degrees.
Bob
RV-10 builder x2
RV-7A under construction
EAA Tech Counselor
Old 09-04-2016, 02:10 PM
Mel's Avatar
Mel Mel is offline
"AN" solid rivets and "AN" screws have 100? heads.
Pulled rivets typically have 120? heads.
Non-aircraft screws typically have 82? heads.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-04-2016, 02:54 PM
Thanks! I was lookin in the manual before I ordered a countersink. Yard store has like 4 different degrees of the same countersink. I appreciate the help
PP ASEL/A&P
Old 09-04-2016, 06:01 PM
Argh. I should type what I'm thinking, instead of what my fingers were saying. "Countersunk pulled rivets" is what I meant. Previous post edited.
Lars Pedersen
Davis, CA
