Old 08-28-2016, 09:58 PM
b1driver b1driver is offline
Default Brake Line Fitting
Im going to try to build my own brake lines out of aeroquip hose and wanted to see if anyone here had an idea where I could find aluminum -4AN hose end fittings for -3AN hose. I have searched but can only find the steel zinc plated variety.
Luis G.
RV-6A O-320 D3G
Old 08-29-2016, 05:49 AM
bret's Avatar
bret bret is offline
Summit Racing . com!
Old 08-29-2016, 06:17 AM
BillL BillL is offline
Hoerr Racing products are have just about everything in stock. (local to me)
Check out the "aeroquip AQP product line". Look it up and download the catalog, it will allow you to match up fittings to the correct hose.
Aeroquip makes dozens of reusable fittings and hoses, so be sure you are getting a compatible combination.
Bill
RV-7
Lord Kelvin:
Old 08-29-2016, 08:19 AM
Luis---it does make a difference WHAT Aeroquip hose you are talking about. There are aluminum fittings out there for the hose, maybe not necessarily for a -3/-4 jump size. We use stainless hose ends for that application with teflon hose.
Tom
Ridgeland, SC
Old 08-29-2016, 09:07 AM
Pressed the easy button, went with TS Flightlines. Thanks for the help Tom.
Luis G.
RV-6A O-320 D3G
