Old 07-15-2016, 03:22 PM
hcccs's Avatar
hcccs hcccs is offline
Question Slick magneto timing
I'm trying to time my 4370/1 Slick magnetos. These have been running on the engine before I purchased it so I'm confident they are OK. I use a timing device with two LEDs and when the points open the lights come on but the lights are out all the time which seems to indicate that the points never open. I disonnected the ignition switch wire from one P-lead and tried it but it was the same. I have timed Bendix magnetos many times and this should not be any different. Am I overlooking something here?
Hans Str?hle
Jodel sold (SE-XEV)
RV-4, flying any day (SE-XJJ)
F?rentuna, Stockholm
Sweden
EAA222
2020 =VAF= $20 donation paid
Old 07-15-2016, 03:29 PM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Timing
Did you put the ignition switch to both?
Al Girard, Newport, RI
N339AG
RV-9
Old 07-15-2016, 05:24 PM
Double check that the box is getting power and a good ground.
Old 07-15-2016, 11:17 PM
cfiidon's Avatar
cfiidon cfiidon is offline
What Bob said... Is there a known good battery in the box? Mine has red/green LEDs so I know if it has power.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 07-16-2016, 01:44 PM
hcccs's Avatar
Don
My box runs off the aircraft battery and it's good. I disconnected the P-lead of one magneto and connected directly to it and there is no change. Can it be anything else than a worn cam in the magneto?
Hans Str?hle
Jodel sold (SE-XEV)
Sweden
EAA222
Old 07-16-2016, 03:07 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Couple of ideas??
These come to mind-----
Bad wire from the external connection to the points/condenser.
Bad insulator at the external connection.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-16-2016, 04:27 PM
rzbill's Avatar
rzbill rzbill is offline
I am curious. You say your mag timing light has two LEDs.
Mine does too. Would it be the following unit, like mine?
If so, it has an internal 9V battery. Unit will not work with low battery.
Bill Pendergrass
ME/AE '82
Old 08-25-2016, 08:51 AM
hcccs's Avatar
Exclamation
Faulty box. I borrowed another one and now all is OK.
Hans Str?hle
Jodel sold (SE-XEV)
Sweden
EAA222
Old 08-25-2016, 05:09 PM
flyingriki's Avatar
flyingriki flyingriki is offline
Also, as infrequently as we use these, take the battery out so it doesn't gum up like they do when left long periods....my A&P turned me on to that gem when I bought a new one.
