Old 08-23-2016, 12:50 PM
russe russe is offline
Default Nose wheel pant attach bracket cracked: advice
I took off the nose wheel pant on my -10 this weekend and noticed a crack. See the attached picture. I suppose that I have to order new brackets from Vans, and then install them. Any thoughts about this issue?
https://www.dropbox.com/s/bcf0mcx8bh...%20PM.jpg?dl=0
Old 08-23-2016, 12:59 PM
YellowJacket RV9 YellowJacket RV9 is offline
Your could probably make a repair with some aluminum and flush rivets, but almost as easy would be to just order and make a new one. By cutting off the ears of the current one and removing the nutplates, you could probably use them as a template to drill the new bracket so everything fits like before.
Chris
Chris Johnson
Old 08-23-2016, 01:18 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
The only reason to repair would be if you are trying to avoid repainting the fiberglass. If you are real good at bending aluminum, you could form a piece of .063" that fits exactly inside the U of the bracket and use a bunch of flush rivets to secure, then cut out the associated slot to match the bracket. This will need to be one piece of aluminum.
I'm guessing just replacing the bracket will be a lot less work. That is what I'd do.
Any thoughts on why it cracked?
Carl
Old 08-23-2016, 02:01 PM
Jesse's Avatar
Jesse Jesse is offline
Just replace them. They are much stronger new than trying to fix that one. You shouldn't need to modify the fiberglass at all. Drill the nut plates and cut off the ears on your old one so you can lay them over the new brackets and drill the same nutplate holes.
Jesse Saint
Old 08-23-2016, 02:20 PM
Gary 40274 Gary 40274 is offline
Default 4130
I have cracks in mine many times. I operate off of grass almost exclusively. I tried repair, double layer aluminum, epoxy layup inside a new one. Finally I made a new bracket out of 4130. So far all good
Gary Specketer
Old 08-23-2016, 03:35 PM
Thanks for the ideas, guys. I think I will get new brackets from Vans and install them.
Old 08-24-2016, 05:15 AM
ghatch ghatch is offline
I'm on my second bracket repair. The first time I bought new brackets and added a doubler. During every preflight I check the rigidity of the wheel pants and every time it has been rock solid. Imagine my surprise when I took the front wheel pant off for my 1st condition inspection and found both the new bracket and doubler with cracks in the same places as before.
I too operate off a grass strip and would be very interested in having a 4130 version of the bracket. Gary, is there any chance of getting them from you? That would be a great solution.
I understand that Rob Hickman replaces his frequently and also operates from grass.
Thank you,
Gerry
Old 08-25-2016, 02:11 AM
paul330 paul330 is offline
I have just started flying from a grass strip. Initially I was keeping the controls neutral and "rotating" at 65kts. It was suggested that I should keep the stick hard back, keep the weight off the nosewheel, hold it just off the ground and let the aircraft fly off when ready (using flap 18).
Waaaay smoother way of doing things and hopefully will relieve some of the stresses on the nose gear and fairings.
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
2019 Donation Made
Old 08-25-2016, 06:45 AM
Default 4130
Thank you,
Gerry
No unfortunately I only made one set and since have lost access to press brake
Gary
