View Poll Results: Have you installed and have you had a failure of your VP system
Installed VPX-Pro
52 |
59.77% |
Failure of VPX-Pro
8 |
9.20% |
Installed VPX-Sport
14 |
16.09% |
Failure of VPX-Sport
2 |
2.30% |
Installed VPX-200
7 |
8.05% |
Failure of VPX-200
4 |
4.60% |
08-20-2016, 02:54 PM
VPX-Pro. Installed over 3 years ago.... So far works great.
08-20-2016, 04:23 PM
Originally Posted by Bill.Peyton
I just had a failure of my Vertical Power VPX-Pro, the elevator trim limits no longer function, nor does the stuck switch feature. It will be going back after we complete our planned trip.
I would like to ascertain the reliability of the VP system now that we have a significant number in the field. Note:
Note:The poll questions are exclusive! If you have NOT had a failure then please respond with Installed XXX
Bill, i would like to recommend you adjust your survey to include " Classic VP 50 & VP 100's. You might get a broader spectrum of the same (simliar) product.
John Mastro
RV-8
08-20-2016, 06:57 PM
2 years and 305hrs
Zero problems
08-20-2016, 07:15 PM
John,
I don't know how to revise the survey. As I recall the older units did not have the dual buss the new ones do.
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
08-20-2016, 07:44 PM
John,
Fair enough.
Interesting survey....good to get some data on the failures.
I was lucky to buy a "new" backup VP100 from a builder who is going with the newer stuff.
Knock on wood....my VP100 has 300 hours/6 years of good ops.
John Mastro
RV-8
08-20-2016, 08:08 PM
failure before 1st flight, solid after that
My VP-X pro failed while I was still building. One of the two controllers died, unit wouldn't talk to the EFIS and switch inputs on that controller didn't work. VP-x (prior to their sale) fixed under warranty. The unit has been solid since- 450 hours in 2.5 years.
Greg Blanck
RV-8 Completed March 2014
Redwood City, CA
RV-8 Build Log
08-20-2016, 11:53 PM
Mine has been working great.
My only complaint is that the builder could have chosen a better location to mount it. Oh wait, that was me.😄
08-21-2016, 03:11 AM
VP-Pro
VP-Pro. 98 hours in 15 months. Rock solid!
Cheers from Downunder.
08-21-2016, 06:40 AM
VP-X Pro installed and working great for 250 hours,
Dwight Frye - Raleigh/Cary NC
http://www.openweave.org/rv7/
RV-7 N4932L/Tip-Up/Superior 180hp/API Fuel Injection/Boss Aircraft Paint
First Flight : September 2, 2013
08-21-2016, 08:29 AM
My VPX-200 failed during construction; probably my fault. But since it is orphaned, I had no recourse. Aerotronics is now rebuilding my panel with a dual VPX-Pro (because the Pro does not have enough circuits to support the G-900X plus backup EFIS plus AC plus EI plus Oxygen EDS.) I'm disappointed in the lower number of circuits and the lack of automated mode switching and the lack of a dedicated display (Garmin does not support VPX on the G-900X) but I guess VPX considers me an outlier. If I were starting from scratch again, I would go with a normal electrical system with breakers.
EAA Technical Counselor #5357
