  #11
Old 08-20-2016, 09:42 AM
StuBob StuBob is offline
I've ordered a plate, but I'm pretty excited about this Type A ProSeal. Just ordered some from Spruce. I bought the pint, figuring the cartridge is only a 50% discount and there's a good chance I'll need it again.
Stu F.
RV8
Old 08-20-2016, 09:55 AM
Bluesky's trick for the back baffle is a good idea; I used a similar trick with Flamemaster pourable sealant (I used Flamemaster brand to build the tanks, too) on my -7 tanks. I forgot that you said the leak was at the outboard end, which gives good access through the filler neck. I used 1/4" nylon tubing with a coat hanger for a stiffener; the aluminum tube should be easier to position accurately.
Old 08-20-2016, 03:49 PM
With my amazing $140 amazon-purchased borescope, I was able to find what looks to be the problem:
I'm pretty sure I can get the ProSeal back there with a syringe and some tubing. But I'm struggling to figure out how to spread it around. I need some way to manipulate this thing from 8" away through a 3" hole:
I could do it with a colonoscope, but I don't think I could get away with borrowing one!
Stu F.
RV8
Old 08-22-2016, 09:41 AM
Snowflake's Avatar
You might not want to... You don't know where it's been! :P
Rob Prior
Old 08-22-2016, 09:44 AM
longranger's Avatar
Or would it be because you DO know where it's been?
RV-7 TU 904KM (reserved)
Construction Log
Old 08-22-2016, 01:57 PM
RichF RichF is offline
Had almost the same baffle leak on my -8 tank . I used a semco gun and cartridge filled with standard proseal, a piece of semi-flexible plastic tubing and a plastic threaded plumbing union which threaded into the end of the cartridge. Use a #10 solid copper wire as a stylet and practice before you mix any sealant. Use gravity to your advantage and it should flo out fine. Worked out well for me...Good Luck
Old 08-23-2016, 05:00 AM
bobnoffs bobnoffs is offline
don't borrow the scope, bring the tank into the O.R.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
