Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
  #241
Old 08-17-2016, 06:37 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Originally Posted by krashmaster81 View Post
I've got a 660 with the GDL 39 3D power harness dock mount. I have been unable to receive attitude information via serial connection provided by the dock. However the ADSB information is passed perfectly. In order to see the attitude info on Syn Vis page, I must connect the 660 to GDL39 3D via Bluetooth, only then will the attitude info appear. Is this normal? Or am I missing a setting? The only inconvenience is that the GDL occupies the single Bluetooth connection that I would rather have available for the iPad.
-Matt
Hello Matt,
You will want to update to V2.60 whenever possible since it removes this limitation.
Some more good news with V2.60. This is the last software update most of us will ever do using the USB cable. After installing V2.60, subsequent software updates will be delivered over WiFi from FlyGarmin automatically.
Each time your aera 660 powers up with a WiFi connection, it will quickly check with FlyGarmin to see if there is new software available for the aera 660. If so, it will ask you if you want to update now, or wait until later.
Another nice new feature is TargetTrend traffic information on the Map and Charts pages just like previously provided only on the Traffic page.
Steve
Change History
Changes made from version 2.50 to 2.60:
Add Wi-Fi software update support
Add display of user waypoint comment text
Add terrain status icon to map page
Add TargetTrend(TM) traffic motion vectors to map page
Add aviation points to Recent used list when reviewing
Add GDL 39 3D attitude data processing over RS232 connection
Add support for 10 different aircraft profiles
Add support for Flight Stream 510
Add Mark WPT button to quick settings control bar
Add VNAV setup button on Flight plan and 3D Vision pages
Improve Wi-Fi Database download processing
Improve ADS-B traffic status display
Improve Connext interface
Improve Data Link Info page weather availability
Improve sunrise/set fields on flight plan page
Rename charts tab on airport review page to 'Charts'
General improvements to system operation
Includes GDL39 software version 4.70
Garmin G3X Support
g3xpert@garmin.com
Last edited by g3xpert : 08-26-2016 at 04:25 AM. Reason: Added link to change history.
Old 08-17-2016, 07:06 PM
krashmaster81 krashmaster81 is offline
AWESOME!!!
Old 08-20-2016, 12:18 PM
Bluebeard Bluebeard is offline
There is mention above of a G-meter that can be reset on the 3D Vision page.
Where is this? It is not mentioned in the manual.
Old 08-21-2016, 10:53 AM
The G-meter appears/replaces the HSI on the 3D-Vis page when you pull around 2G. OR if you go inverted. However, you can manually replace the HSI with G-meter on the 3D-Vis menu pages. I think it's under the "more options" button.
-Matt
Old 08-21-2016, 10:58 AM
Originally Posted by g3xpert View Post
Hello Matt,
Steve,
This update did the trick! I think the AHRS data seems to be much more robust now that it's streaming via serial.
However, I have not been able to find "Add VNAV setup button on Flight plan and 3D Vision pages" options in the 2.60 update.
-Matt
Old 08-21-2016, 11:25 AM
g3xpert's Avatar
Post
Steve,
-Matt
Hello Matt,
Select Menu on either of these pages and you will see the VNAV setup button in the button bar.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 08-21-2016, 05:07 PM
Low Pass's Avatar
Low Pass Low Pass is offline
Great to excellent with the updates!! Thanks!
Bryan
Houston
Old 08-22-2016, 05:18 AM
g3xpert's Avatar
Post
Hello,
In addition to what Matt posted above in response to this question, we should point out that the G-meter functions are not available unless the aera 660 is connected via RS-232 or Bluetooth to an external attitude source like the GDL 39 3D ADS-B receiver or one of the ADS-B In/Out GTX 345/345R/45R transponders.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 08-24-2016, 07:17 PM
Jetguy's Avatar
Jetguy Jetguy is offline
In regards to installing an external receiver antenna for the GDL39 on the bottom of the plane, does it matter how close it is the the actual transponder antenna since its receive only?
John
RV12 N1212K
Flying Since June 2010
1020 Hours as of 9/30/2017
Johnrv12@icloud.com
RV14 Wing, arrived and building at Rdog's new Hanger at 16X
S/N 140014
Old 08-24-2016, 07:40 PM
Mich48041 Mich48041 is offline
Yes, it does matter. But the actual minimum distance is controversial. How about as far away as practical and convenient? I would try for 2 feet or more. Less than that might not be a problem, but why chance it?
Joe Gores
RV-12 Flying
