Old 08-17-2016, 05:00 PM
Super Moderator
Default Electronic
How about electronic ignition? Anyone running that, too.
Vic
Vic Syracuse
www.Baselegaviation.com
Old 08-17-2016, 05:05 PM
Auburntsts's Avatar
Vic
Nope--Slick retard breaker mag with Slickstart on the left, Slick plain on the right
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 08-17-2016, 05:10 PM
woxofswa woxofswa is offline
Bendix 1200's for me.
Myron Nelson
Mesa, AZ
RV-10 N24EV
KITPLANES Contributing Editor
Old 08-17-2016, 05:13 PM
Weasel's Avatar
Weasel Weasel is offline
Bendix, Lightspeed
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1600hr counting
Fisher Classic Cassler Power VW sold
RV-10 N7631T 820hr Sold
RV-8 700+hrs
Carbon Cub 200 hr Sold
One-Off Super Cub 100 hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
Old 08-17-2016, 05:52 PM
DanH's Avatar
DanH DanH is offline
A front governor is driven from a location near the crankshaft's fundamental vibratory node, which means it would see very little vibratory amplitude even if the crank was doing the Chubby Checker
For the youngsters who may be present: https://www.youtube.com/watch?v=pHGXwQeUk7M
Duh.....wrong!
That's what I get for writing without thinking. The governor is driven off the forward end of the camshaft, which, in terms of torsional vibration, is likely to be a very active location.
Dan
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-17-2016, 05:59 PM
Walt's Avatar
Walt Walt is offline
Anybody know off hand what the ratio is for the governor this way I could look for it on my spectrum analysis runs.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 08-17-2016, 06:43 PM
Super Moderator
Default Ratio
.895:1 for the IO-540
Vic
Vic Syracuse
Old 08-17-2016, 08:48 PM
N402RH's Avatar
N402RH N402RH is offline
I am currently in the middle of swapping the MT for the Hartzell and this is not proving to be easy. The control arm location is totally different and it looks like I will be talking to Hartzell in the morning.
Rob Hickman
N402RH
Old 08-18-2016, 01:48 AM
gerardb gerardb is offline
Rob Hickman
N402RH
Please post the reply from Hartzell. I'm in the process of doing the same swap.
Old 08-18-2016, 04:12 AM
Weasel's Avatar
Does anyone have information on the 4th failure that has been mentioned? Was it also a C4B5?
Weasel
RV-4 715hr Sold
RV-8 700+hrs
SERFI AWARDS
