Old 05-21-2016, 02:51 PM
DHeal DHeal is offline
Default Finishing Plugs and Caps
If you want to fill those somewhat unsightly tooling holes on your RV-12's wing tip bows and stab end ribs, you might want to use the following finishing caps:
-- Hillman Arrow Clips - Nylon (White) #394150-C (for the 3/16" holes)
-- Hillman Arrow Clips - Nylon (White) #394148-A (for the 1/8" holes)
I found these at my local ACE Hardware store.
To seal-up the ends of the foot steps, I used the following plastic end-plugs:
-- Hillman Round Cap Plugs (Black) 3/4"
I found these at LOWE's.
http://imgur.com/cvypRxR
http://imgur.com/sfrHrIh
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
VAF donation through June 2021.
Old 05-22-2016, 06:05 AM
f1rocket's Avatar
f1rocket f1rocket is offline
Your picture link isn't working.
When I tried to put plugs in the end of my steps, they kept blowing off in flight. I may try these again if they'll stay put.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 05-22-2016, 09:38 AM
Randy -- I think the photos should work now. Three of the step plugs have stayed in place for 300+ hours without glue. I added a touch of contact cement to the left forward step plug since it would occasionally ease out a bit due to my foot hitting it. -- David
Old 08-15-2016, 08:27 AM
Chrysopelea Chrysopelea is offline
Bumping another old thread.
There's a great glue called "Amazing Goop" which I believe used to be called "Shoe Goo" when I was younger (same product as far as I'm concerned) but it's a rubber based glue that holds with the power of epoxy, but has a little give like that of stiff rubber.
I Q-tip and a dab of gas or toluene easily undoes anything glued with this glue, so it's only for non-solvent parts or areas.
Amazing Goop is just that! It's an incredible glue. It does shrink a little when applied thickly.
Old 08-15-2016, 11:43 AM
magiccarpet's Avatar
magiccarpet magiccarpet is offline
Where will condensated water escape when you close the tooling holes? Just a thought.
Chris, RV-12 S/N 120832, HB-YSC
Facebook: http://www.facebook.com/magic.carpet.aviation
YouTube https://www.youtube.com/channel/UCLw...nv3vJiqAYoE-dg
=VAF= dues paid for 2020
Old 08-15-2016, 03:03 PM
aerofurb aerofurb is offline
Cessna flap wear buttons work well, too, for the 1/8" holes (if I remember correctly), certainly works on the wing tips and stab end rib tooling holes:
http://mcfarlaneaviation.com/Product...umber=S1093-1&
Jerry Parr
England
Ex RV-12
Loving Rotax....
Old 08-15-2016, 05:15 PM
The water pumps pump that water out lol. What? Your steps don't have internal condensation water pumps?
Mine has one of these in each step.
https://www.google.com/search?q=big+...sOz-nBhZPMM%3A
Old 08-15-2016, 05:31 PM
XOverZero's Avatar
XOverZero XOverZero is offline
Yup. That Bad Boy'll git 'er done!
John Halcrow
Tustin, CA
RV-12 120682
Emp/TC done; Wings done; Fuse kit done
"History teaches us that men and nations behave wisely once they have exhausted all other alternatives." --Abba Eban
Paid up until Aug 2021
