Go Back   VAF Forums > Regional Forums > Midwest
  #11
Old 08-09-2016, 04:31 PM
jrs14855 jrs14855 is offline
Default Airpark
Not in WI but only about 10 miles across the IL line. Check out Poplar Grove, C77.
Old 08-09-2016, 05:38 PM
Kevin Horton's Avatar
Kevin Horton Kevin Horton is offline
I really appreciate all the suggestions. We've got some research to do
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 08-09-2016, 06:27 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I flew a photo mission out of Poplar Grove just before Oshkosh - pretty impressive place!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-14-2016, 05:53 AM
Dave Bernard's Avatar
Dave Bernard Dave Bernard is offline
How is hangar availability in this area?
I'm considering moving there from UT... after the -8 is done of course!
"Almost Done"
CAF Stearman pilot
Old 08-14-2016, 06:02 PM
MartinACFactory's Avatar
MartinACFactory MartinACFactory is offline
Kevin,
I am sad to read you are planning to leave Ontario. Will you still be flying occasionally in Eastern Canada ?
I am making good progress on my RV-8 build. I hope I may still count on your help someday for my RV-8 initial flight testing program ?!
Best of luck with your move in the Mid-west USA.
Martin
Martin Leroux
CPL ME-IFR & CFI Class 3, 1,400+ Flight Hours
Terrebonne, Quebec, Canada
RV-8 s/n #80414
Kitlog: http://www.mykitlog.com/MartRV80414/
Empennage: 100%
Fuselage: 95%
Wings: 99% (Flaps remain to attach)
MD-RA Pre-closure inspection completed Dec 27, 2019
Entering Final Assembly Phase !
Old 08-14-2016, 07:19 PM
Originally Posted by MartinACFactory View Post
Kevin,
Martin
We certainly won't be moving this year, as there are a lot of things to sort out first. Maybe in the second half of next year, or in 2018.
I'd be happy to help out with your flight testing, but given the complications of travelling back and forth, you should probably look at some of the other test pilots with RV-experience in the Ottawa area.
Kevin Horton
RV-8
Moses Lake, WA, USA
