Old 08-06-2016, 07:49 PM
AviatorJ AviatorJ is offline
Originally Posted by Lynnb View Post
I like those SPHERICAL FIREWALL FITTINGs, what size did you order for the three control cables?
Would also like to know this. I plan on working on my firewall a bit next and will be installing 3 eyelets.
Justin
RV-10, N10JW
First Flight 2/14/2019
http://operationrv10.blogspot.com/
Old 08-07-2016, 05:29 AM
steve murray's Avatar
steve murray steve murray is offline
Originally Posted by flion View Post
However, I am using sealed CPCs for my passthrough
Sorry, can you educate me on what a sealed "CPC" is? I am probably 1 year + from working on firewall but trying to learn.
Thx
Steve
Steve
RV8 Flying since 2007 - Now for Sale
RV10 - Flying (Jan 2020)
Old 08-07-2016, 08:37 AM
flion's Avatar
flion flion is offline
Thx
Steve
Try here: http://www.omega.com/pptst/MTC_CONN.html. Actually, CPC is a bit of a misnomer because they are not plastic; they have aluminum bodies and a bundle shell (about 3" long) that serve to protect the connection from flame and heat. The pins themselves are bedded in a flexible synthetic material that is supposed to be fluid-resistant.
Understand that they are not flame-proof. But they are way better than Circular Plastic Connectors and probably as good as many of the other pass-throughs in common use, where the weak link is burn through of the wire insulation being passed. The idea of such devices (shields and such) is to minimize the exposure and grant a little extra time (seconds?) to deal with a fire incident.
So why not just use one of the simpler and much less expensive solutions available? When I had my landing incident in my RV-6A, I had to replace the fire-wall and a couple of the stringers behind it. This meant that I had to undo connections to thermocouples and sensors, etc. and thread them all back through the firewall. The worst were the connectors for the Lightspeed ignitions, 25-pin soldered connectors on the cold side to the crank sensor circuit board (potted connections) on the hot side. It took some large penetrations and creative shielding but I managed it. I also decided that the automotive approach of a connector at pass through was the way to go. In the -10, if I need to remove the engine, I won't have to decouple each individual CHT, EGT, etc. Instead, I will just have to undo the starter cable, grounding strap, and two bundle connectors (not mentioning fuel and oil lines). If (gods forbid) I have an incident similar to the one I had before, replacing the firewall won't involve a lot of wiring work. And I carried the idea through the plane. Replace a rudder? Just wire the rear strobe and trim servo to a CPC in the bottom fairing and attach to the connector already routed from the fuselage.
The downside of connectors is connector reliability and maintenance (plus initial expense). But you can select good quality connectors with some research and maintenance is not difficult during inspection. Consider the reliability of the connectors already in use in lighting systems, for example. But, as with everything else in experimental aviation, it is individual choice and preference.
EAA Technical Counselor #5357
Old 08-08-2016, 04:14 PM
jwilbur jwilbur is offline
Sorry for the late reply to this question. I got the 0.260 size. They are installed on my firewall right now, but I haven't run the control cables yet. I determined the size by measuring the control cables I have - standard cables from Van's in the FWF kit. I did do a test fit before installing the fittings and they looked good.
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
RV-10 Build Log
Old 08-10-2016, 01:22 PM
Lynnb's Avatar
Lynnb Lynnb is offline
FYI: After drilling this and working on this new hole for the P27 battery cable in the firewall I'd recommend doing something different than the wiring plans. If you do drill the hole, cut the end off the cable and crimp a new end. With the crimp size on the cable, it will not fit a 1/2 hole. I had to upsize to 5/8 and now I'm looking for a bushing. Had I give more thought I'd have just cut the end off the cable. My .02.
Lynn
fyi: If you look at the Van's wiring harness plans, they actually drill a different hole next to the skin to run the battery cable through.
RV-10 in Process
Old 08-10-2016, 02:07 PM
Evolution10 Evolution10 is offline
If your looking for some of the best and safest, look at:
http://www.doubleteeproducts.com
They made the exact sizes I needed for all my pass-through needs.
Highly recommended!
Old 08-10-2016, 02:49 PM
Putting together a BOM for my Firewall and Tunnel.
Fore the firewall the jist is I'm going to use Stainless Steel passthroughs and grommets, with sandwiched Fiberfrax and 0.002" stainless foil. I'll then use 3M Fire Barrier 2000 as both an adhesive for the Fiberfrax to the Firewall and the Foil to the Fiberfrax as well as any gaps.
I'll do something similar to the tunnel as well, but will be Fiberfrax, insulation and then the foil...
Anyone see any issues with this?
Also where can I source 0.002" stainless foil?
Justin
RV-10, N10JW
Old 08-10-2016, 03:05 PM
Default Foil
McMaster Carr has it...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 08-10-2016, 03:15 PM
clutch22 clutch22 is offline
While you're at it, you may want to purchase one or two of those Airward tunnel access covers.
Andrew Austin
RV-10
-Flying!
Old 08-10-2016, 03:35 PM
Thanks!
Done, installed one on the passenger side a few months ago.
Justin
RV-10, N10JW
