  #71
Old 08-07-2016, 11:49 AM
Sam Buchanan's Avatar
been here awhile
What are you guys using for day-to-day canopy cleaning? I'm not so concerned with scratch removal (I've got some Meguiar's stuff that works well for that, and I've heard the Plexus recommendations), but something mild for bug and smudge duties. Thanks!
Best thing I've found is liquid dihydrogen monoxide applied with a synthetic chamois.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 08-07-2016, 11:58 AM
Chkaharyer99 Chkaharyer99 is offline
I've been using plain water on a terry cloth towel. I place the dry towel on the wind screen, pour clean water on it and let it marinate a few to loosen the dried bugs. Dry with a clean dry cloth. Works very well.
Charlie
RV-8
Old 08-07-2016, 12:22 PM
I use the same chemical, but I've read that a clean digit tip from a Homo Sapiens is the safest tool.
I do use something like
https://www.amazon.com/Original-Wate.../dp/B00II5YADC
to remove the chemical.
Charlie
Old 08-07-2016, 12:38 PM
zampano's Avatar
zampano zampano is offline
Ammonia Free Windex and a microfiber cloth, for the occasional really stuck on things Turtle Wax Bug And Tar Remover.
Jim Anderson
RV-7: #74811
N54WW
Way I remember it, albatross was a ship's good luck, 'til some idiot killed it.
Old 08-07-2016, 12:46 PM
flyingriki's Avatar
flyingriki flyingriki is offline
Originally Posted by RV8JD View Post
REALLY like this stuff. Easy on and off, unlike plexus where it seem as you can't get it all off without looking from all angles and rubbing and rubbing....
Old 08-07-2016, 12:48 PM
Plummit's Avatar
Plummit Plummit is offline
I first spray the plastic with soft water until the water runs off the windscreen with the surface dust. I then use a clean micro fiber to wipe the water off. Each wipe is from top to bottom, and I turn or fold the micro fiber so that each wipe is with a clean piece of cloth. I then use 201 plastic polish spray from Aircraft Spruce to polish the windshield, again with a clean microfiber using up and down vertical strokes.
It's a technique I learned when I was actively flying sailplanes and it works well for me. The most important thing is to try and rinse the dust off first, as that's what causes the scratches the impede visibility. YMMV
~Marc
RV-10
N814RV
2020 Donation Made
Old 08-07-2016, 12:54 PM
aerhed aerhed is offline
ElCheapo furniture polish. Definitely not windex. Also, my homo sapiens digits leave scratches.
Actual repeat offender.
Old 08-07-2016, 01:14 PM
Carl Froehlich's Avatar
Never any household stuff like Pledge.
Novus #1 for everyday cleaning.
Novus #2 for any light scratches or fog (like paint overspray)
Novus #3 for bad scratches.
A 2 quart jug of Novus #1 will last for a decade of use. All are available at Aircraft Spruce.
Carl
Old 08-07-2016, 02:49 PM
Carl
Exactly. The Novus products are a good value and work well.
If my canopy is dusty, I'll give it a squirt with plain old water to wash the dust off before I begin rubbing it with anything.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 08-07-2016, 09:37 PM
Hmmm. I know cropdusters that use pledge by the case. A can per day. What's your problem with it?
